Serpent 710
#3962
Hey D, your averaging 10 post per day for 2 years
You need to spend more time with your wife
#3963
Originally posted by S710_Nut
The only thing i do not like about this car so far is the e clip on the 2 speed. the cut in the shaft seems to be too narrow or the clip is not big enough
SN
SN
#3964
#3965
#3967
the rear springs require more preload for ride ht because they have more leverage on them from the suspension arm, has to do with the shock being mounted on the arm instead of on the upright, same deal with the lsa conversion, this is also why large numbers of you have gone to the red rear springs to help loosen the rear of your cars.. make it feel like the old car.
#3968
Originally posted by InitialD
Are you checking the tweak with the rear sway bars on or off? Perhaps you need to check if the rear sway bar by itself can move freely without binding...
I try to explain better; my question is : When I lift the rear, is it ok if the rear springs become ‘uncompressed’ before the wheels lift the surface? Seems that the preload is not enough to ‘push’ the suspension arms down until the stop (done by the downstop grub screw, I mean).
TNX
#3969
Which is what I'm doing...
#3970
what are you running for rear droop, I very very rarley ever run less than +7 rear droop, that is 7mm above the chassis
#3971
My rear droop is +7, 7mm above the bottom of chassis
#3972
the spring should be plenty long to push down, very very odd, with my spring couplers at the yop of the threads it pushes my arm to the grub screw,?? not sure.. can you posta pic?
#3973
Originally posted by EVOLUTION
Does your wife also race?
#3974
Re: Re: Re: KHM
Originally posted by GoldFinger
Down here, country with thousands island and problem either.
Sorry if im being so but i dont like that character either and I like the fact that he is faster than you..
#3975
