Serpent 710
Originally Posted by B4
I use a teflon based lube that pushbike racing riders use on their chains. This lube has the added benefit of not attracting dirt.
cvd's
Thanks for the reply's. Yes i'am using oneway .
Run the car 2 meets but justed oiled' there braking on ball end were pin goes throw for cvd.
Originally Posted by redsand
The local track was supposedly designed for electric cars. It is approx. 60' x 130'.Technical, lots of 180 degree hairpin turns, 25 deg banking sweeper, & tight turns too.
Are you going to try 30k?
Originally Posted by _cyclops_
Do you have a brand that makes that lube? I've been searching for something like that... it seems it's more sticky then the teflon grease from Robbe/Graupner...
Originally Posted by jag
Banking sweeper Nice!
BTW, are you watching the Orange Bowl at the moment ?
Just to let you know about the lube.
Brand: TRI-FLOW
Description: Superior Dry Lubricant with Teflon
It's a wax based formula, but it is very thin.
In Australia it's available from good Pushbike shops $14.95 for a 59ml container.
Hi _cyclops_
Brand: TRI-FLOW
Brand: TRI-FLOW
Thanks m8, never seen that brand here, but i'll start searching and hunting
Rear Gear diff
What oil should i run in my new gear diff
Track is tight to medium & traction is low to medium grip;but for summer nats last year car did traction roll when grip came up 'they dont spray surface.I have mugan diff oils 30000 & 50000 would one of these be any good.
CHEERS !!!
CHEERS !!!
CHEERS !!!
CHEERS !!!
Has anybody compared diff oils from different teams?
With sedan body shell I'd go with 30K. Running with Lola body tends to have more rear bites, causing it to understeer, therefore it needs heavier diff oil.
I was watching the game but it got boring in the 3rd quarter so I went to bed. I guess I missed the exciting part.
Sway Bar
Has anyone tried an RRR front sway bar on their 710? If so, what do you think?
I tried it last night and I had a lot of steering but the car was a little difficult to drive but it may have been the track.
front gear diff?
After this succesfull rear gear diff, can we expect a front gear diff released soon ?
New Mega ZX12 Conrod (by Picco)
Hiu Guys
We have the latest conrod by Picco. Now, beside having awesome performance at a very good price level, we have also reliability. We have already stock of rods as spare parts. The engines we have in stock (both engine only and Powerpack) will be supplied with the old conrod installed (we reccomend to use it only for breaking in the egine) and the new one as a spare at no extra cost. After we sell all our inventory, the new batch will come with the new one already installed.
Paolo
Serpent USA
Hiu Guys
Paolo
Serpent USA
Hiu Guys
Paolo
Serpent USA
Hiu Guys
Paolo
Serpent USA
