Serpent 710
Originally Posted by jag
I accidentally mounted my body about 1/8" - 3/16" too far forward compared to the wheel openings in the body. How bad did I screw this up?
Thanks,
jag
Thanks,
jag
Originally Posted by markp27
Some bodys work better with the body mounted more forwards - I like the Mazda mounted pretty well forward, at least 4mm, which is between 1/8th and 3/16ths. You should be fine
Thanks,
jag
CVD's Pins?
Originally Posted by Julius
Be carefull when replacing the pins in the new cvd's. They're a smaller dia and need to be replaced with pins designed for the cvd's I saw them today in the Serpent warehouse (the number is one higher than the m3X3 screws)
Thanks in advance
I use the m4 hole of an old alu motor mount and place the mount on a large vice. Then using a heavy hammer hit the pin till it's flush with the ball. Then take a driver (the things to embed nails in wood with) and tap it out.
The second part did not work for me... i also don't understand what kind of 'driver' you are using... i've tried using a center-mark-tool for metal to center it before you drill in metal?... that doesn't stay on the pin and keeps bouncing around (logical, with a point)... i tried cutting a peace of the point so it's flat, but i just could put full pressure on it because the dogbone just wanted to go away and it just doesn't stay still without holding it....
so, what kind of driver is this really you are using, and any tips on how to use the old motor mount and keeping the dogbone in place?
Erh, it seems that some pins are just harder to get out, and i just started with that one :S
two dogbones are really hard to get the pins out, the other two where just easy to do... damn, that was frustrating
Originally Posted by _cyclops_
The first part works great, the old mount from the 705 is now 'deformed' a little, the ball fits nice...
Great then
i have got them all out btw, some hard work and i do think its a bit of a hassle, maybe i need some training in this
Front Diff
I am going to be racing on a track that's approx. 75' x 150' with 13 turns. The track flows pretty good but the turns are pretty slow (square) so it seems like having good brakes would be an advantage. So what would be the best to use in the front, a diff, a one-way or a locked one way? If the diff is the way to go, how would you set it up?
Thanks,
jag
Thanks,
jag
Use a diff. As loose on the clamp as possible. If you go too loose you'll notice the back end will slide under power. Too tight and you'll not have enough steering into the corners.
Use a higher rear roll center. Bottom top and top-inner-upper.
Also the body makes a lot of difference. I'd try a losi alfa or a stratus 3 as they are easier to get round small corners than a mazda.
My set up is the following:
REAR - UTI / LB Front
Front – 1mm under
Front Tire – 37 Shore / 63mm (this is only at the qualify at MAIN is 62 / 63)
Rear Tire – 40 Shore / 64mm
Front Ride Height 5.5mm (I have the new Chassis plate S802121)
Rear Ride Height 6.0mm
Body Stratus I think is 2 but sure is not 3
Front Diff. is medium Hard
Rear Diff. is soft
What can I improve to solve the Traction Rolling?
Jose
How do you 'know' what roll-center settings are best at what track? This is a thing i really need to concentrate very very very hard on to understand, the basics are easy, but what setting to set is just a mistery to me...
@ rc panama:
I'd try using 37 shore rear too, or a 40 shore in front.
Use the rear roll center settings I described before: rear Lower top. Upper top inner.
This rear roll center position is wat I use all the time now. It does give a little less rear traction, but the slide is much more controllable, and you'llget more steering (I run a 45-90 degree upright front bar most of the time). In combination with the same shore tires you may get better balance.
I think you are using the different shores to get more even tire wear? If so you may want to try the 21t pulley with a 3mm split in tire size. Reset front downstop to 1.5mm lower than what you run now. I find it makes tha car more predictable and less prone to traction roll. But I must say it seems to be a personal choice
Check: http://www.mytsn.com/publ/publ.asp?pid=10984
Unfortunately nothing is always the same. So sometimes you really need to try stuff all over again on different tracks. The "theory" is only that!
Julius, how does the new chassis fit into all this together with the 21T aluminum side pulley? Any changes to the roll centre, droop etc?
BTW, I may be late on this one but it's one of the coolest looking chassis around.
Hopefully some pictures will come in.
