Serpent 710
Anyone got or know where to get the new aluminium pulleys for the 710??
Originally Posted by sparksy
I'm running that engine at the moment.
stock gearbox except 18t first geer on the bell.
hard spring
adjuster screwed in 1.2mm
clutch gap 0.5
yellow shoe
hard spring
clutch gap 0.5
yellow shoe
Ok, thanks went I use the same setting it is hard for the engine to star (slow star), could this be a wrong setting in the engine?
Originally Posted by ntc3freak
are u sure uncle sow???? then i'll just wait for it.thank god i haven't bought the 710
(Michel - you can send my advertising fee with my next order )
Originally Posted by New_Toasted
In sweden we have a 710 "RTR" Ready To Race (not prebuilt) that inculdes lightweigh middleshaft and pulleys, vented brakedisc, antirollbar kits and the front and rear "crash kits".
The stock 710 costs in sweden (hold on to your chair so you won't fall off) 665 USD! And the "RTR" 695 USD!
If you mean when the engine is running and you try and get the car to move, if the engine revs very high, then you have tightened the clutch spring pre-tension nut too much.
Send us some details of how far onto the pre-tension nut is screwed down - measure from the top of the screw thread to where the pre-tension nut is.
Cheers, Mark.
Serpent 720 or Serpent 118 or Serpernt F180
Originally Posted by Sow&Steady
You wouldn't believe what they're working on!
We just need to wait and see. Serpent are normally good to keep the card very close.
rccobra705
Originally Posted by gfd2726
Hi guys,
I am looking for upgrade parts to make my stock 710 go faster. Any suggestion? So far, I came up with these:
Titanium Middle Shaft
Titanium Main Shaft
Titanium Pivot Balls
Thanks!
Titanium Main Shaft
Thanks!
On top of these there is the new chassis (802121) and the 21T (802171) alu pulley - these two are excellent tuning options which make a real improvement to the 710.
Cheers, Mark.
Originally Posted by rccobra705
If it is a Tractor Puller or 1/18 scale car, then won't believe it, but if it is the Serpent F1 then I would believe it. But on the other hand, why are they start to sell 2/3 1100 mah batteries?
rccobra705
rccobra705
Cheers, Mark.
Originally Posted by markp27
Do you mean to start the engine on the starter box? This has nothing to do with the clutch settings.
Cheers, Mark.
Cheers, Mark.
Not really with the starter box, what I mean is when I accelerate. The pre-tension nut is 1mm in from the screw thread.
Watch your car in the pits as you start to give some throttle with your controller - does it start to move as soon as you start to open the throttle? If yes then add more pre-tension. If you open the throttle quite away before it starts to move and the engine revs quite highly, then it maybe that you have too much pre-tension.
It is very difficult to tell you exactly how to setup the clutch without being there, but the engine should rev a bit before the car starts to move - but it shouldn't rev too high.
Check the clutch bell temp after driving for a while - in my experience, it shouldn't really get over 60 Degrees C - if it does, then this probably indicates too much pre-tension or a badly setup clutch.
Cheers, Mark.
New Serpent rumours
You can kill the 720 rumour - it isn't that!!!!
Cheers, Mark.
Cheers, Mark.
I am agree with you. It is to early with a new 1/10 200mm. It could be a new 1/8, but not as we know it today. I believe it will be the Serpent F180 formual 1 car.
Regards
rccobra705
Mark
Regards
rccobra705
Regards
rccobra705
Cheers, Mark.
Cheers, Mark.
Cheers, Mark.
Jose
Steering throw
Originally Posted by InitialD
I believe this was covered way back... Shortened
Cut the metal (the stock rod linkage) down to 17 mm. Stock lenght of the rod linkage is 23 mm from tip to tip.
As for the plastic, trim the length of the ball cups. The picture attached shows the top one being the original (and uncut) and the bottom one is the one that was trimmed.
This combo gives the total length of the ball cups and rod linkage assembly as 39.5 mm instead of 44.5 mm as per the manual.
At neutral position, the steering servo horn is not in the center. It should be leaning forward slightly at neutral position with this linkage mod.
