Serpent 710
Originally Posted by fulcrum2
Hi!
My used 710 came with a shim between the 1st and 2nd pinion gears, but in the manual is no shim visible.
Do I have to use the shim?
Many thanks in advance!
Serpent 710 RC
Anybody there know what a 710 RC is!!!! Found this at RB Product's web (french version).
Also exist a 950RC!!
RB Product is french distributor of Serpent. Check link:
http://www.rbproducts.com/main.php?p...Stat04=SERPENT
Regards
rccobra705
Regards
rccobra705
Originally Posted by f2000racer
YES! you have to. It is actually not in the manual. Go to www.mytsn.com and search for the 710, i believe it's an additional flyer or instruction sheet.
The Snake 710 RC is the new version of the 710: it profits from the experiment of the TEAM at the time of its first season when it practically very gained! Champion of Europe, Champion of France, conveys year, the 710 receives some improvements aiming at ensuring its supremacy! Stage of anti-roll aluminum bar, blocking of front free wheel, bars anti-roll back 2.5+3mm, but also new safe-servo and cast solid driving support! It is ready to gain!
FINALLY!!!!
Well at last, after about 16 months of trying, I managed to break my original thin rear shock tower - I went too fast into the chicane at my circuit, flew over a curb and landed squarely on the next curb, right on the rear tower Now the rear section of my body shell is bent completely out of shape Never mind - I'll probably be using the 2,1 Stratus this weekend
Also I tried out the 21 tooth alu side pulley - man this made a huge difference in the long left hand corner leading onto the straight - I could get onto the gas much, much earlier than normal and the car held a much tighter line at the exit. I thought the motor was down on power at first!
I ran the tyres with a 2mm split - seems to be a keeper for me.
Cheers, Mark.
Cheers, Mark.
Cheers, Mark.
Cheers, Mark.
The 21T is a huge improvement, allows you to be much more agressive with the throttle and still maintain the best line. Are you also using the front diff ? I've found this recently to be a great advantage on all tracks since I change to the 3 racing friction collar.
Originally Posted by B4
Sorry to hear you have finally been able to break the shock tower, I'm still trying.
I am using the front diff and the two part diff collar. What difference did the 3 racing part make for you?
Cheers, Mark.
Don't give up matey....you'll get it one day
I was stunned at the difference it made in the fast sweeper - I'm looking forward to using it in anger tomorrow.
Cheers, Mark.
Cheers, Mark.
perhaps in FAQ 2.4 you can describe the correct breaking procedure
It's took me a while to adjust my driving to suit the advantage we now have with this pulley.
The 3Racing diff collar has a teflon ring inside the collar and in my opinion this is makes it more tunable and improves consistency through the race. Having said that I would rather use the new part that Rene said is on the way as Serpent quality is No1, price's on the other hand could be revised i think.
Cheers, Mark.
CHEERS MARKP27
Bobby here,how are things good i hope.
Cheers, Mark.
Cheers, Mark.
To the Winter Nats!
jack
I'll wait for Serpent's own
Cheers, Mark.
I've got mine already.
Originally Posted by Sow&Steady
Why wait? You guys didn't see the post at 3hobby.net?
Can you post the link to you post, I've looked at 3Hobby and can't see it.
Simon
Regards
rccobra705
Regards
rccobra705
Sow
Simon
Simon
http://3hobby.net/modules.php?name=N...rticle&sid=501
