Serpent 710
Originally Posted by Rene C.
You wish it, we do it.
Rene
Rene
Rene
Rene
Ok, we will make an aluminium clamp ring.
To be honest, it is already done. I used it a long time, to find out the right material, also Kolff and Keur used it. Both where happy with the result.
Rene
Rene
Simon
Originally Posted by B4
I'm going to wish for some more things Rene.... I check tomorrow to see if you have also tried them.
Simon
Simon
hehe, give one vinger, take the hole hand?
Wish list
Rene
Rene
It would save me some machining time.
Originally Posted by Sow&Steady
O' Master ... will there be a 16t pinion that works better than the current one? Or is there a tip or two that ensures it works consistently without problems?
proto 3.1 stratus
I tried the new 3.1 stratus body yesterday and boy let me tell you.That body made such a difference in the cars turning and stability it was amazing.You guys should try it!!
Originally Posted by Julius
Here's a tip: Use a Mega and you don't need 16t
guys,how good is the yellow seal bearings over the standard one????
does the mono block engine mount fit the new os .12 tz???thanks
cvd
where could i buy the serpent universals (cvd) cant seem to find it in online stores
Originally Posted by acutts
Not available yet I believe ... I was told next week from my LHS ...!!
Hi!
My used 710 came with a shim between the 1st and 2nd pinion gears, but in the manual is no shim visible.
Do I have to use the shim?
Many thanks in advance!
