Serpent 710
#2011
Re: Re: Re: Re: Re: Steering Linkage Pic 2
Originally posted by GoldFinger
Really..???
Really..???
Julius fly's planes for a living for KLM I believe.
Cheers Alastair
#2012
Then i realize the rear trackwidht is 202mm and nothing i can do since the upperlink ball is screwed maximum. Pyramid suggest me to cut the ball and I did cut 3mm off.
Check my photo, you will never be able to do that without cutting your balls!! (I mean stock aluminium pivot ball)
Then after adjusting the lower ball to kept 200mm trackwidht, my car is even better.
#2013
Originally posted by clmbia45
Julius, I've been meaning to ask, I know working for Serpent must be very profitable, but isn't it a bit MUCH to put a picture of your private plane on your posts??
KLM also would object slightly if I were to make a 500km/h flyby of the Serpent factory
#2014
Originally posted by InitialD
[BWhat does Team Serpent think this? Since the 710 was designed from the ground up, why was this overlooked since the bulkheads could be made to shift a little bit behind? [/B]
#2015
Hey 100 posts!!!!!! Only 10000000 to go before I catch D
#2017
MISSING FRONT ONE WAY GEAR
Julius,I am assuming you are with Serpent.I bought the 710 and it has the wrong front one way gear.What is in my kit appears to be a diff gear with 3 pins on back side and round hole in middle instead of hex.Hobby shop says call Serpent USA,Serpent USA is closed for 2 weeks and probably won,t have parts anyway.Can you be of any assitance on this.Don,t mean to put you on the spot just trying to get help.Thanks
#2019
#2020
Re: MISSING FRONT ONE WAY GEAR
In all fairness, there is not a lot I can do....
Serpent USA is the right place to help you. You could try to send an e-mail to Ronald Baar at Serpent HQ. [email protected]
#2021
No not an oversight. With the tower in "your" position it's difficult to reach the front screws of the diff holders.
#2022
#2023
I test and race for them but I do not get paid.
#2024
Originally posted by Profoxcg
should I start putting my car together or not???
#2025
Serpent 710 Pics - Part 1
Ok, as promised, here is an onslaught of pics I've taken. Enjoy !
