Serpent 710
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Just Info
Originally posted by GoldFinger
Still .12 club member ?
Re: Re: Mazda 6?
Originally posted by crashed_1
Cut the hole in the wing struts...or you could flip the rear body post around it'll barely miss the wing struts...works both ways.
http://www.mytsn.com/publ/publ.asp?pid=10313
Hmmm...we wonder why?...
Anyone has a set-up for the W'nats? Who's going?
Super Moderator
Originally posted by markp27
I'm going, but I don't have a setup
Track conditions:
Track (if not listed):
Air temperature: 65
Track temperature: 80
Traction: good
Track surface:
Race condition:
Results:
Qualifying result:
Qualifying position:
Best laptime: 13.8
Final result:
Final position:
Best laptime: 13.9
Suspension geometry Front:
Downstops: 0mm
Set-up ride height: 6mm
Camber Left: -2 degree
Camber Right: -2.5 degree
Track-width: 198mm
Toe-in: -2.0 degree
Caster setting (mm in front): 4mm
Roll-center position upper arm (mm): 4mm under
Upstop (mm): 2mm
Suspension geometry Rear:
Downstops: 7mm
Camber Left: -2.5 degree
Camber Right: -3.0 degree
Toe-in: +2.0 degree
Track-width: 198mm
Roll-center position upper: low mid
Roll-center position lower: low
DRS arm position (low-mid-up): up one
Shockabsorbers Front:
Springs: red
Oil: 40W
Holes: 4
Cilinder type: composite
Shock-tower position: 2nd hole
Shockabsorbers Rear:
Springs: red
Oil: 40W
Holes: 5
Shock-tower position: 1st hole
Lower shock position: outside
Anti-roll bar front:
Thickness: standard
Position: flat
Anti-roll bar rear:
Thickness: standard
Position: 4mm from end of bar
Position on lower arm: outside
Tires Front:
Make: Ellegi
Hardness Left: 40 shore
Hardness Right: 40 shore
Diameter: 61.5mm
Wear in 5 min. Left:
Wear in 5 min. Right:
Tires rear:
Make: Ellegi
Diameter: 62mm
Transmission:
Pinion 1st: 17T
Pinion 2nd: 22T
Gear 1st: 60T
Gear 2nd: 56T
Front axle:
Type: one-ways
Diff. setting:
Rear axle:
Type: adjustable diff
Diff. setting: medium
Aerodynamics:
Body: stratus v2
Wing: #170103
Gurney strip: 1mm
Engine and pipe:
Engine: NovaMEGA
Version: #2106
Head shims: 0.3mm
Glowplug: 6TF
Pipe: #2171
Header: #2174
Length:
Fuel: 30%
Remarks:
Chassis performance: chassi very stable under braking,overall very good, Needed a little more steering under acceleration
Engine performance: very good
Test remarks: Try different clutch waits, made out of the clutch shoe It gave a more positive engagement
Thanks, Marcos, but this is an old one - the circuit has been relayed and the setup will be somewhat different now.
Cheers, Mark.
Cheers, Mark.
Super Moderator
Cheers, Mark.
Cheers, Mark.
hey do you need a 75 mhz radio for the nats?
I think I may well do - but also 2 rx units I've asked on the Starting Grid forum and it seems that 40MHz isn't exactly forbidden.
Do you have a spare 75MHz module?
Originally posted by Marcos.J
oops!
oops!
Super Moderator
Super Moderator
Are you going to the Winternats?
No but i might be able to get one for you ,What radio do you have ?
Cheers, Mark.
yes im trying to,
yes im trying to,
Someone took some pictures from Morganti's car and I'm sure he'll get it posted on here. Morganti was already running in the high thirteen's so his setup should be close.
