Serpent 710
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Aluminum Pulleys
Originally posted by InitialD
I think I get what you mean... Less inertia from the front wheels means front wheels turn easier when power is applied. But how does the front wheels rotate more than the rear when both are doing the same rollout and especially when both front and rear wheels and interconnected from the same drive train and power comes from the same source?
Its like where the front go, the rear will follow.
In 710, using 46T diff with 2.5mm split I can have that feeling but not with 45T / 1mm split.
BTW, maybe you can ask "Serpent guys" to reproduce 46T diff, the ratio is right in the middle of 21T (2spd)pulley.
I think you're playing with too much jumping and dirt ! Get back to onroad and you'll start thinking straight.
p/s: Forgot to mention that I received the stuff in good order.
(Hey, Im not Tina Turner fans )
p/s too : How come ?? should be less 1 Meha item ?
I had a wonderful day today with the 710, my second time running it. I am very happy with the performance and handling, managed to follow some lola bodies car on the track. Solid front axel is really fun to run. Then came the rain. Only managed to run 3 tanks. Thumbs up to serpent
serpent 710
hey does any 1 have any idea as to how the serpent would get more top end out iof it by changing gears or gear ratio?
thanxz
Davo, KO PROPO
NOVA MEGA
SERPENT 710
HUDY SET-UP STATION FOR MEGA GRIP WITH AWSOME POWER!
LOLZ
thanxz
Davo, KO PROPO
NOVA MEGA
SERPENT 710
LOLZ
Re: serpent 710
thanxz
Davo, KO PROPO
NOVA MEGA
SERPENT 710
LOLZ
thanxz
Davo, KO PROPO
NOVA MEGA
SERPENT 710
LOLZ
Generally the top end is determined by the second gear pair (this is the inner pair (pinion closest to the engine and spur closest to the rear block).
The best way to work this out is to calculate the gear ratio between these two i.e. spur divided by pinion.
For example if you used the 55 teeth spur and 23 teeth pinion, the ratio is 2.39. This means the pinion needs to make 2.39 revolution for each 1 revolution of spur. The bigger this ratio the more the pinion has to turn for each revolution of the spur.
You can generally conclude that the smaller the ratio, the more the top speed your car can go.
So what is going on with the price of RC cars????
710 = $225.00
G4 evo = $260
The serpent 950 reduced fro m 610 to 390!!!!!!
The new Picco engines .21 around $290!!!!
And this is on the run up to xmas!
Anybody got any ideas?
710 = $225.00
G4 evo = $260
710 = $225.00
G4 evo = $260
710 = $225.00
G4 evo = $260
710 = $225.00
G4 evo = $260
710 = $225.00
G4 evo = $260
Originally posted by Ferdi
Where did you see the 710 for $225.00?
Go to rc-mushroom.com under car kits to find the s710 for $225us.
cool thanks
710 = $225.00
G4 evo = $260
710 = $225.00
G4 evo = $260
Where did you see these prices? They certainly seem very good value!
The border says "Lowest price" and yet its selling the 710 for the equivalent of USD 485.
Mushroom is at USD 225.
I hate to say it but perhaps mushroom is getting out of supplying Serpent stuff and clearing their stock or they know updates are coming for both the 950R and the 710 are coming.
Re: Dogbone Pin Mod
Since today is technically very much Friday on some parts of the world, here is a pic of the mod done on the dogbone pins.
The dogbone side that goes into the rear diff outdrive gets the longer side of the pin (3 x 11.7 mm). The other side of the dogbone is with stock pin (3 x 9.7 mm).
The longer pin is said to be more prone to wearing the diff outdrive. Time will tell as I've yet to test them.
The 3 x 9.7 mm stock pin on the bottom right, you could see that the tip is pretty flattened out after a while. If you see this on your dogbones, do not panic. You can resuse the pins...
Just take a vice, a hammer and something sharp and pointed so that you could use it to hammer the pin out of the dogbone. After getting the pin out, you could turn it 90 degrees and hammer the pin back in again to resuse it. The flattened and worned out part should no more be in contact with the surface of the outdrive and to the outdrives, the dogbone pin would look like new.
Good mod D.
Serpent will probably come out with the same design but with either Hody's spring steel or their own OEM spring steel. If they don't plan to then Julius will read this say "Hey! That's a good idea!" and then go knock on Pieter's door. Right Julius?
Originally posted by Sow&Steady
There is something going on here.
Unless any of you guys can reccomend me an asian stockist?
Originally posted by Brett.w
I think they are getting out of selling serpent all together after trying to order parts for my 710 alot seems to be out of stock! and i hate to say this but if rc-mushroom quits serpent iam going to have to change vehicle as there is no serpent stockist over here
Sounds like it could be a business opportunity for you? Open a shop specializing in Serpent in NZ!
