Serpent 710
Re: Re: Re: Dynamic rear steering
Originally posted by jag
It seems like the car pushes a little up front and the rear seems a bit loose. I am running 37 shore tires all around at around 62mm.
I know the setup is something I will have to find on my own but I just want to know if I should be working with the DRS. Does using DRS effect other settings or is it a stand alone adjustment? Meaning, if I set the car to use the DRS will it require other adjustments to make it work right?
Re: Whats up
Originally posted by Wap
Any new items, upgrades or etc. that I need to be aware about.
You should be looking at the following stuff...
SER-802145 Servo lever front long S710+diffring
SER-802162 Middle shaft alu coated S710
SER-802212 Body-mount front long alu (3)
SER-802220 Bracket front up alu L+R orange
SER-802337 Anti-roll bar sets 2.5+3mm
SER-802362 Body-mount short rear aluminum (2)
SER-1388 Thrust-bearing 5X10 ceramic
SER-9607 Race brake-padset L+R
SER-802155 Bracket middle shaft alu
SER-802136 Bracket radioplate-support alu
SER-802552 Engine mount mono-block S710
SER-802241 Anti-roll bar levers + ecc. Alu
SER-802235 Spacer st-block-uprights (4)
You could also look at Thomas' post on what he added to his 710.
BTW, I would suggest that you check the rear diff outdrives and the rear drive cups. Check to see if there is any kind of wear. You need to inspect closely in order to see it. If they are worned out, change them. That's probably the cause of the problem with the rear spinning out to one side.
Re: Re: Re: Re: Re: Dynamic rear steering
I don't really know how to adjust the ball diff other than making sure it doesn't slip when you hit the gas.
I am using the yellow springs, 35wt oil and 3 holes on the shocks. By damping I assume you mean shocks?
Re: SWB
What tool do you guys use to cut the 1mm off of the arm... razor knife, bridge port, etc...?
For more details, you could refer to Onkel Sow's article here.
Originally posted by InitialD
Yes. Just mount the spurs onto the 705 oneway 1st gear oneway hub and the 2nd gear aluminum hub.
In fact, you can take the whole 2 speed gearbox from the 710 and fit it on the 705. Just make sure you use the correct aluminum spacer at the back of the 2nd speed aluminum hub. When you do this, make sure you use the 2 tension springs in the clutch shoe from the 705 one and not the one that comes with the 710 because the 710 is much softer and will cause improper and earlier engagement in the 705.
You may need to do some dremelling in the engine mounting holes on the chassis of the 705 so that the engine mounts can go further slightly to the rear to mesh the spurs as the 710 spurs and pinions are slightly smaller in diameter.
You can also use the 710 purple engine mounts on the 705 chassis. They are the same except the 710 ones are 1 mm lower.
Using 18/60 and 23/55 when using the 710 gears on the 705 wil give you the same rollout as 15/50 and 19/48 with the stock 705 gearbox and clutch.
Re: Re: Whats up
Of D's list I think these are the important ones.....
Especially the servo lever and diff ring are imrovements to the car. The anti-roll bar increases your tunability.
Re: Re: Re: Whats up
The only drawback is that the gear ratios of the 710 are different. So you'll have to use different pinion/spur combos.
Cheers, Mark.
Just popping the new servo saver in your existing car would make the neutral center of the steering about 30 points off to the right. Also the wheels will toe out more like -3 or -4 per wheel. I have not checked that.
Re: Re: Re: Re: Whats up
Originally posted by markp27
I haven't got the 802145 set yet, but the Anti-roll bar kit is brilliant!
I installed the new servo saver last night.
Re: Re: Re: Re: Re: Whats up
What!! only last night, that is unacceptable!
So we don't differ in this instance.
Had it very LONG ago. I just wanted to test out all the things I wanted to do before swapping for the new servo saver in.
Friday pix...
It's Friday guys...where's em pix?
Re: Friday pix...
