Serpent 710
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Anyone with a 710 kit which has a copper colo
Originally posted by InitialD
You need BIGGER room !
Originally posted by Picard
Mark
Also, do you use grease on the thrust bearings and what condition is your spacer between the bearings in?
Mark
Re: Re: New Tyres
Yeah, PRECIOUS ! I'm also using Speeminds at the moment. My car track width is set to the Ellegi rims. What I do when I use SM is I use spacers made out of lexan that I cut in the same shape of a hex that will space it out nicely back to 200 mm. No need to turn out and in the pivot balls.
Re: Re: Re: New Tyres
Originally posted by markp27
I used Lexan, too, but found it squashed too easily, instead, I use Tamiya spacers - they make some nice Alu ones in 1mm and 0.5mm sizes.
Originally posted by Sow&Steady
Pyramid, what engine was Teddy using?
Would you believe is I told you he is using a plain RR12L3?
No problemo!
I've been using them right from the begining to try and reduce the chances of getting a pillow ball pull out - seems to have worked very nicely.
And the final results? Well ... go here to see.
Originally posted by Pyramid
No doubt, V1RRR design interested on S710 adjustability, the use of low internal ratio and taking it further to G4 (the one the use to copied them) low center of gravity... Sure it also lacks some point here and there but their efforts (in everything) has been paid off
Have you guys any news about the RRR being used in competition prior to the WC? It was also used at the European Champs, but with only one made it into the final.....but I have no idea how good the driver was or how many RRRs were entered.
Man, Kyosho are getting great press from us all, aren't they
Uncle Sow, that is not TS car you put in
"A special thanks to Andrea Rossi from all of us in Indonesia for noticing Teddy's performance and finally giving the 'much needed' full support to our 'hero' in those difficult condition..."
"Much needed" full support from Andrea Rossi would mean engine support... That would mean a Sirio engine of some sort to use... Any insights on this?
Anyway, congrats ! Hope it will be an Indonesian Surikarn in the making. Sad that it was not Goldfinger. I always thought he had potential. (j/k)
Their effort is what I admire. Well done!
Re: Re: Anyone with a 710 kit which has a copper coloured 17T gear?
[B]Do you have the black flywheel? Are you using the brass cone that comes with the kit?
I'm actually interested if someone used the same Sirio in the 710, what would have happened...
And yes, strange enough, NO Novarossi engines or varients in the top 10 A main ! So you guys with JP FX engines, IDM or NovaMax engines, better sell your engines cheaply to me ! muahahah
