Rubber tires on carpet?
I am going to be running my first sedan this year and am going to be running rubber tires with a stock motor. What tire does anyone recomend? Most are using the take-of 27's where I race. Also what are your maintanence tricks. I.E. cleaning and compound combinations. All help will be greatly appreciated.
Re: Rubber tires on carpet?
-Sushi Boy
for the BEST traction ever get sorex 24's front and 20's on the rear u will have so much traction most people at my track use them
I have found a couple of combinations to work for me. Pit 27 front-Pit24 Rear with an echo red insert. <- thats with paragon
Take Off 27 front-Take Off 22 rear with Jack the Gripper. If I wanted more steering with Take off's I would go to 22's all around. Sorex 28's all around work well, have not tried with 24's in the rear.
Make sure you clean the tires , especially with the Gripper, they get a buildup on them. Off all the combinations, I really liked the Take Off 27/22.
i run the take off 27 on front and rear. i clean them with rubbing alcohol and use TQ Blue as traction compound. most guys run a one-diff in front but that makes it handle a lot different.
I would recomend rubbing alcohol over Simple green. I know simple green make tires FEEL sticky, but ........... its soap! A little rubbing alcohol on a rag, wipe off the tire, then apply your sauce. MUCH BETTER
is the traction compound for foam tires the same as those for rubber?
no, TQ makes different solutions for foam and rubber, but you can use one for the other if you have to.
rubber tires
Thanks for all of the replies so far. I talked to a guy at the track the other day and he suggested cleaning the tires with lighter fluid. Anyone else heard of this?
Regional Moderator
When I ran rubber tires in stock, I used the sorex 24s in the front and 20s in the rear w/ hpi medium inserts but tried the take off 27s and never changed. I ran a diff in the front, center one way, thick sway bars, 80wt oil all around and stiff springs. I cleaned the tire w/ some trinity rubber tire cleaner and paragon for tire traction compound. I wish we had another rubber tire stock class, My cars just was right on with them. I did prefer the take off pre mounts more than the sorexes. Hope this helps.
Phatt,
All I ever cleaned my carpet rubber with, was a towel and a little dab of whatver traction compound. I would just rub the crap and buildup off of the tires that way. The suggestions to run a one way, are good. I have yet to find a carpet track I am faster with a diff, but that is for my driving style ( or lack there of ).
Any word on the carpet nationals??
