Like Tree3Likes
Tamiya TRF415
Old 05-27-2005, 06:13 AM
  #9016
TryHard's Avatar
yeah i remember that too.... not a good meeting.
broke 3 lwt rear arms in one day ... hence why i had to switch back
TryHard is offline
Old 05-27-2005, 06:36 AM
  #9017
acutts's Avatar
Originally Posted by F. Alonso
What heatsink beam do you speak of?
Tamiya TRF 415 Heat Sink Beam 49344
acutts is offline
Old 05-27-2005, 07:18 AM
  #9018
F. Alonso's Avatar
Oh right... I remember. Seems like a bit of a pointless hopup, but if you want all of em.. go for it.
F. Alonso is offline
Old 05-27-2005, 09:50 AM
  #9019
Customworksking's Avatar
Trader Rating: 74 (100%+)
Default dway10000
Originally Posted by dway100
Your right - 1.193 is the lowest. I wouldn't even run my lathe with that crappy of a pack.
what u do-n- on a tamiya page go to X-ray that's d-way mon
Customworksking is offline
Old 05-27-2005, 11:17 AM
  #9020
tamiyarcracer's Avatar
Originally Posted by FW-05RR
This new 415 update is it a whole new kit? or is it something the 415MS can evolve to
From what I can tell ya. The update looks like it is just that. It looks like it uses a 2.5mm version of the regular TRF415 chassis.
tamiyarcracer is offline
Old 05-28-2005, 07:53 AM
  #9021
Bad Boys Racing's Avatar
Hi, i'm looking to buy a Tamiya TRF 415 and i have a few questions.
Do you know if AE TC3 springs fot the Tamiya shocks? or if any, but tamiyas do?
I hear that Jaco 28mm Foams don't fit, is that true?
I heard the top deck can tweak easily if you hit the bords, is that true?
Are there any little tweaks in the car, like little problems, or things that break easily?
Bad Boys Racing is offline
Old 05-28-2005, 08:36 AM
  #9022
Trader Rating: 42 (100%+)
yes...AE springs fit fine.
I ran 28mm parma and TRC foams no problem...as long as you're talking about the stock suspention TRF415. If you are really concerned you can get the 4 or 6mm wheel hexes to push them out further. But it's not necessary.
I don't believe that's true. With the stock 3mm lower, mid-decks and topdecks the 415 is very solid. In the past I ran a Pro4 and that thing got tweaked all the time. With the 415 I really don't have that problem. During the indoor season I ran the car on carpet/foams.
The stock 415 is a solid car. I don't think anything breaks easily. But with any other car I would just stock on arms, knuckles and hubs. The MS or LW suspension is not as sturdy as the stock suspension.
Hope that helps.
Nexus is offline
Old 05-28-2005, 09:09 AM
  #9023
thanks, that answered all my questions!
but i thought of one more, i've never had a belt drive car how should i take care of it?
Old 05-28-2005, 01:47 PM
  #9024
Jack2's Avatar
Well since your used to a shaft driven car, going to a belt driven one is probably going to be a little bit of a shock because it does take a bit of time to get use to the lay out and changing belts can be a headache for the first few times but when you get used to it it's easy. As far as taking care of it, one thing you have to keep an eye on if you race outdoor's is the pulley's on the car, as sometimes small object's (rocks) can get jammed up in the pulley's and slow your drive train down and destroy your belt if you leave it in there. Another thing is just keep an eye one your belt tension, it shouldn't be too loose, but should never be to tight, just stick with the stock setting and it should be good. Can't really think of much else, but changing belts on race days can be slowed down if you change your belts fairly regularly and don’t leave damaged ones in when you know the haven't got much life left in them.
Jack2 is offline
Old 05-28-2005, 02:57 PM
  #9025
this car will be purly carpet, so check for crap in the belts and make sure they arn't tight? what is tight? how long the belts last before i have to change them? the car has 2 extra black sets plus a white set on the car. how do i tell a belt is wearing down? When you say getting used to the layout of hte belt what do you, the way it performs or the way the chassis is set-up?
the car i'm buying doesn't come with a manual, does anyone have a computer verion i cna't find one on tamiya's site
Old 05-29-2005, 03:08 AM
  #9026
Burlap's Avatar
I've got a PDF scan of the manual here (415 only, not MS):
http://www.maths.monash.edu.au/~killjoy/415manual.pdf (6MB file)
Burlap is offline
Old 05-29-2005, 03:26 AM
  #9027
Jack2's Avatar
Well since your going to race carpet, then I asume you shouldn't have to worry about small objects getting jammed up in your pulley's too much.
With the belts tension, they seem loose at the standard setting but it works very well.
Not sure how often you race, or what class you race, so I'm not even going to try and estimate a life span on your belts, but when they start to fraigh or split, then they should be replaced.
I am sure someone who races one carpet can tell you a rough life span on belts.
Jack2 is offline
Old 05-29-2005, 04:34 AM
  #9028
Looking at getting a secondhand TRF415 , do GP3700 cells fit right without any or much work to the chassis ? The TRF415 will do me until the new beltdrive comes out.
Dunno what it is about the TRF/EVO range of cars but i always seem to come back to them sooner or latter , just carn't get other makes of car to go as fast or get the results like i can with the Tamiya's.
weekendracer_uk is offline
Old 05-29-2005, 04:38 AM
  #9029
Jack2's Avatar
Depends how much the chassis was filed out for the previous cells. I'd say you might have to file the slots out a little more with 3700's.
Jack2 is offline
Old 05-29-2005, 04:41 AM
  #9030
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Mine fit in great. I did buy my car used but when they sanded the chassis slots they did a fine job on them and 3300 and 3700 cells fit with zero problems.
wyd is offline
