Like Tree3Likes
Tamiya TRF415
Old 08-17-2004, 10:23 AM
  #3316
Originally posted by TryHard
Excellent, cheers for the info. I'll use my cut down ones first... I have 8 to get through
Ed
Hello Tryhard,
Are the e-clip slots on the hinge pins in the same place for the Evo III hinge pins as the 415 hinge pins. I will not be able to check them until friday.
I just bought 2 sets of evoIII hinge pins form speedtechrc.com because steve said they were a direct replacement.....interesting....
Obsidian is offline
Old 08-17-2004, 10:43 AM
  #3317
TryHard's Avatar
not sure exactly, I'll have a quick look.
The pins I replaced are the inboard ones, so didn't actually need e-clips, but hence why they need to be cut down.
Ed
EDIT - Right, had a look, I think I know where the confusion has come in, the outer pins ARE a direct replacement, however the inner ones aren't.
TryHard is offline
Old 08-17-2004, 10:58 AM
  #3318
On another note, I founs out a few things the yesterday
1) EVO3 suspension pins are too long for the 415, by about 2-3mm. However the pins can easily be cut dwon using a dremel...
Ed
Hello Tryhard,
sorry, wrong quote the post before.
Obsidian is offline
Old 08-17-2004, 11:00 AM
  #3319
Hello tryhard,
Thanks, I appreciate your effort.
Obsidian is offline
Old 08-17-2004, 11:06 AM
  #3320
Tryhard,
What type of surface are your racing on?
What Class are you running in?
What is your setup?
Obsidian
Obsidian is offline
Old 08-17-2004, 04:05 PM
  #3321
TryHard's Avatar
Check my post on the previous page (third up from the bottom) thats what I'm running in stock.
HiH
Ed
TryHard is offline
Old 08-18-2004, 01:21 AM
  #3322
V12
V12's Avatar
Ed
Thanks for the Excel sheets!
V12 is offline
Old 08-18-2004, 01:26 AM
  #3323
TryHard's Avatar
Glad you like 'em.
Hopefully the set-up crib sheet aint too confusing, I find it quite useful to have a look at if I'm stuck tweaking a set-up, and it means that a) I don't have to flick through the guide to find the right section, or b) remember what change does what. Also can remind me if I've forgotton to look at something.
Regards
Ed
TryHard is offline
Old 08-18-2004, 01:28 AM
  #3324
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by V12
Ed
Same here!!! much thanks..very usefull info there that you sent me
-Dave
JDM_DOHC_SiR is offline
Old 08-18-2004, 02:22 AM
  #3325
chambalero's Avatar
Default Re: QUestion.........
Originally posted by lem2
okay--- it's a stupid question.......
I know the 415 is a world class, champion and fast car!!
But anyone here, who owns a 415 and a TA04-R?
Could you make a comparison? I have hopped up my 04 to kingdom come and would love another belt car and 415 is my first choice!!!
QUestion is.......Is it worth it?
Any tweak issues? since I prefer a tub chassis (less tweak?)
Thanks!!!!
hey lem!!!
how are you?
i own both but i haven't used my 415. i bought my 415 also asking first if it has any tweak issues. apparently, it has none. sonny had a super crash in captiloyo but he was still continue no problem you can ask him. i think tweak problems are pretty much confined nowadays to shaft driven double deck cars. i actually almost bought an evo4 the other day but when i checked the forums, the tweak problems were present. that's why i bought a cgm instead yesterday be careful cos there are no parts for sale, you have to order at pitshop. i'd suggest if you can wait for the myo2-m, it might be worth considering. or you can offer to buy mine hehehehe. but in all honesty, even with the lack of parts availability here, based on inputs from a lot of people, i think the 415 is worth it
chambalero is offline
Old 08-19-2004, 10:24 PM
  #3326
Does anyone know if a light wieght front axle exists? Part #???
Cheerz
Obsidian is offline
Old 08-20-2004, 12:19 AM
  #3327
If you mean alluminum dogbone...try one from the Evo3 or TA04 (same suspension arms & stuff).....if you mean something else.....sorry bro
The Black Kat is offline
Old 08-20-2004, 06:16 AM
  #3328
Turbonium's Avatar
Trader Rating: 27 (100%+)
Cheerz
you can use the Tamiya #53681 for a titanium wheel axle, and the aluminum driveshaft bones are 53502...
Turbonium is offline
Old 08-20-2004, 08:26 AM
  #3329
rtypec's Avatar
The Evo3/414/415 aluminum universal shafts are 42mm in length, the TA04 shafts are 39mm. The Evo4 are 46mm. Save yourself the money and DON'T get the TA04, they're not long enough...
Also, the aluminum bones up front is pretty risky, if you don't plan on hitting anything and it's a pretty big race, by all means, go for it...
rtypec is offline
Old 08-20-2004, 08:33 AM
  #3330
Ballsie's Avatar
aluminiums up front sounds quite dangerous!
Remember there is the lightweight front joint cups and the mentioned titanium ends.
Ballsie is offline
