Tamiya TRF415
#2896
tcmerf,
Your car looked pretty good for being out there for the first time Most of the guys ended up going with the red sway bar today (it seems like the way to go for the day) so you were on the right track. You might want to check the axle height of your car (most of the tamiya guys like Fred M. and David Jun check their droop setting at the axle height now) Fred suggested 24mm for the front and 25mm for the rear (measuring from the ground to the top of the axle). However, Fred warned me that if you're going to use this method, you have to make sure your camber is set correctly on each corner because camber angle can drastically affect axle height. We are measure the camber angle now off of the aluminum hex hubs (not off the wheel). Give that a try, it could the little bit of handling you're looking for
Steve Wang
Steve Wang
#2897
Yeah, I'm finding my 415 has way too much steering for what I can use on our track. Causes the rear end to step out all the time. I've tried everything I can to dial it out but with no luck. Only one step left and thats to run different compound front to rear tyre compound (rubber).
Is anyone else running their cars on slippery ashpalt? Are you able to share your setup?
#2898
Steve, thnaks for the help yesterday. I did not have any kick up in the front so i added a small spacer like you suggested. I was thinking on the way home and the car acts like it is transfering to much weight back to front so i may try a little thicker oil as well. I was running the yellow Tamiya oil with 2 hole pistons. I am a little confused about the droop measurement though. by the way the lather works great, thanks again. The only bad thing is now i have to wait a whole week to try it out!
#2899
Lycan try this, tighten up your rear diff a bit more, i bet at the moment it spins quite freely. tighten it up till you get a more smoother tighter diff feeling this instantly cured my rear end skipping out
#2900
Also just got back from the reedy, Ben Cosgrove finished some awesome racing with a respectable 5th overall
#2901
Is there any race coverage?
#2902
ok guys, I have a question. When I go to tighten my diff, I can turn the screw very easily, but I can just keep turning it, it will feel like it is getting tighter, then lossen, then tighten, then loosen (feeling), but the diff never tightens up. I take it apart, and the screw is fine, the nut isnt stripped, and the little plastic piece isnt stripped. I should be able to tighten it till I cant turn the screw any more (at least, I could on my other cars).
Thanks,
Mike
Thanks,
Mike
#2903
Are you sure the nut isn't rotating inside the plastic housing? That's what it sounds like it's doin to me. I've had that happen. Replace it. Next time, just tighten down the screw finger tight til you just feel it bottom out. Don't go any farther than that.
#2904
@ Mike
maybe stupid point but :
make sure the ball thrust bearring is in the diff ......
#2905
Originally posted by FastP
@ Mike
@ Mike
#2906
#2907
how tight do yous run your diff?
mine is so that its on the verge of slipping but doesnt and slips the belt.
is this to tight/loose?
when i apply throttle out of corners the back spins.
i think i have to do it up tighter?
any advice appreciated.
#2908
then one of my teammates checked my car out...
"Chris! YOUR FRONT ONE WAY IS ON BACKWARDS!!!!"
[insert homer simpson] doh!!! [/insert homer simpson]
talk about a rookie mistake!
#2909
Originally posted by Hebiki
funny you mention this... yesterday... my car was doing the same thing. i didnt know what it was.. set up? tweak? i thought my belts were skipping.
the instruction manual says to put the one way pully round the wrong way!
it wasnt that tho its the rear diff iam sure someone else here said their back end was unsettled and they tightened the diff and it was ok.
#2910
oh and a big thanks must go to everyone who helped with some set-up advice a few pages back.
it relly helped.
THANK YOU
what a nice tamiya community we have here!
cheers
it relly helped.
THANK YOU
cheers
