Tamiya TRF415
#2266
Paul, this is common with the rear optional hubs. Just shim it accordingly.
The Kai chassis also looks like Masami's Yokomo Chassis that he ran for the Japanese Nationals. Hardly any cutouts... just milled down low.
#2268
Originally posted by Paul_Kultcha
I installed the TRF blue 1degree hubs onto my TRF415, and I noticed there is some play in the hubs now. The bearings can slide in and out of the hubs a bitif you pull or push on the axle.
Anyone else getting play like this? I was going to buy some shims/spacers to take some of this slop out. I know it needs to move a bit to protect the bearings, but I don't think the bearings should shift in and out of the hub like that.
#2269
i hope some one soon comes up with a diff for this car [I][COLOR=blue]
#2270
I just saw the German guy who made the custom oneway for the EVO3 makes an aluminium front diff for the 415 now.
Donīt know anything about prices yet. But anyone interested should send me a PM.
blue anodized front diff looks like this
#2272
Originally posted by tamiyadriver
gee... is your pm box full yet? im sure there are several looking for this deal.
My PM box isnīt full but yes there is some interest.
If anybody else wants sending me PM Iīm not able sending you message back as Iīm leaving for a qualifying race for the nationals in some hours. I will be back on monday.
#2273
#2274
Aluminium rear uprights
Hi,
I was just wondering if someone could tell me the advantage (in terms of handling) of Tamiya's aluminium rear uprights (option part for the EVOIII) which has the ball connector on top rather than the middle. I understand that it can also be used on the 414, 415 and TA04 series.
Thanks.
Thanks.
#2275
Hi Guys,
I ran my 415 for the first time today. Really nice to drive apart from a general lack of steering
I'm going to try the turned upside down A Mount and C Mount at the front of the car but I'm a little confused as to how this gives me more steering?
Is it the adding/removing of spacers under the upside down A Mount that allows for the tilting of the arms (increasing caster)??
Cheers
Lycan
Cheers
Lycan
#2276
Lack of Steering???!! Not here... Where are you lacking? Goin in? Coming out? Mod? Stock? 19t?
The aluminium rear hubs gives more tuning options. 3 verticle holes as opposed to 2 horizontal. Plus you can shim them as well. Plus they are 1° as opposed to the stock 2°. So you can get less caster with D Block in the rear.
#2277
Mod, Going in... pushes really badly
I changed the front end to softer shocks settings (spring and oil), angled the tops in, increased front toe out and also reduced the rear toe. It made it better but some more is still required. Figured I'd try playing with caster next.
I'm also keen on getting those rear uprights but I cant find anyone with these in stock.
Lycan
Lycan
#2278
Lycan,
Try sweeping the front arms; inboard toe out. Also I noticed a big improvement in steering by playing with the wheelbase, not too much though as the car will be twitchy. You might also want to adjust the droop on both ends.
Hope this helps.
Hope this helps.
#2279
I'd play with the rear droop. Let the arms hand down alittle more. I ran a 10x1 KR for practice for Stock Class. Car had some push too. So I just pulled all the droop screws out in the rear. Seemed to help. Plus I went from White/Front Blue/Rear Springs to Yellow Springs all around. This helped too.
I really like how easy the car is to drive in Mod. This is the first time running a mod in this car. It's pretty easy to tune too. I'll try it out some more next week.
#2280
SD vs 415
Right now I am runnng a SD that has about half the Rayspeed kit.
I am lucky enough to live fairy close to Tamiya and it would be cool to be able to head out there on Saturdays. Anybody have both cars and can give me a comparison?
