Tamiya TRF415
4 front & 5 rear is what I was told to run. This means the front arms hang 1mm lower than the rear...
415ms
Guys,just wondering I switched out the front diff for a one-way and now one of the front cvds seems to bind up the steering when in just the right spot!What could this be?
To stop them moving, put either an o-ring, or a bit of shock foam (the red bushing) into the outdrive.
HiH
Ed
Gearing for Team Orion 10.5R
anyone run BL Team Orion Vortex 10.5R? May i know what will be the best ratio to run? I currently running a TRF415MSXX (Converted from MRE), and final drive ratio of 5.88, high speed seems not fast enough
gearing
Mark M
4.6 wont it affect the top speed? I thought longer track should have higher FGR to get higher top speed?
what belts should i use if i run 36T pulleys for front n rear n 18T center pulleys..? thanks...
Cyclone front belt and T2, T2'007 rear belt
Longer gears = numerically lower
Shorter gears = numerically higher
415 MS
I ran my 415 for the first time last night and I broke a RF arm and pulled the screw out the bottom of the c hub or some call it upright.Does anyone make a aftermarket c hub or would you suggest sticking with the stock one and just stop hitting the wall?
Use an 3x10mm button head screw instead of the same size countersunk screw, up into the bottom of the knuckle. The extra thread will keep it from falling out. I pre-tap my knuckles before installing, and I've never had one of these button-head screws fall out.
Can anyone point me to a guide to understand the suspension blocks, I want to increase my track width but need to understand all the 1XA 1E 1X 1D etc etc.....
Thank you,one other question,Do I need to convert to HB knuckles or find different hex adapters to run my larger VTA tires so they stop rubbing?
