Like Tree3Likes
Tamiya TRF415
Old 06-29-2007, 03:42 PM
  #18736
JimmyMac's Avatar
This was 19t/10.5 class. I didn't crash but just clipped the sweeper wall which tends to have little edges that can grab tires or axle studs. And it was only the right side as you can see the multiple times/bends that I clipped the wall. I think the hardened axles will be fine in the rear. Just play it safe and go with Ti up front for club racing.
JimmyMac is offline
Old 06-29-2007, 05:43 PM
  #18737
Tek Nickal's Avatar
Its unlikely you will feel the difference between the aluminum and titanium ones, let alone the steel ones. I would just stick with the steel axles.
Tek Nickal is offline
Old 06-30-2007, 12:01 AM
  #18738
miccal's Avatar
Trader Rating: 23 (100%+)
If I get the short suspension arms (53928) will I need to replace my 46mm swing shafts with 42mm ones? I am running 1A-1B suspension mounts on the front and 1XB-1D suspension mounts on the rear.
miccal is offline
Old 06-30-2007, 01:30 AM
  #18739
Eirik's Avatar
The 46mm shafts will be just fine, it's what I have been using lately with the same arm mounts
Eirik is offline
Old 06-30-2007, 05:22 AM
  #18740
ttso's Avatar
Short arm is only short for about 0.8mm. So unless your 46mm shaft is dangerly close to outdrive, I don't think you need to use 42mm.
Last edited by ttso; 06-30-2007 at 06:14 AM. Reason: Mind switched to TA05, corrected..:p
ttso is offline
Old 06-30-2007, 06:57 AM
  #18741
miccal's Avatar
If they are only shorter by this small amount, do they really make much of a difference?
miccal is offline
Old 06-30-2007, 07:12 AM
  #18742
xtrememadness's Avatar
what exactly do the short arms do? i mean how does it change the handling characteristics? and do you guys use londer mounts. thanx i want to try them.
xtrememadness is offline
Old 06-30-2007, 08:04 AM
  #18743
ttso's Avatar
0.8mm on one side = 1.6mm on trackwidth. Plus, it change almost every characterastic of suspension.
ttso is offline
Old 06-30-2007, 08:20 AM
  #18744
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
longer arm=The long arm setting offers the most
consistent setup for most tracks
Short front arm length will give the car more steering with less stability
rear short arm will give the car more steering by letting the car roll more, which could be advantageous on small tight technical
tracks.
Marcos.J is offline
Old 06-30-2007, 07:45 PM
  #18745
Burlap's Avatar
I've run short arms at both ends and love it. I look at it from a reliability point of view - they don't break as easily as the long arms.
Burlap is offline
Old 07-01-2007, 10:14 AM
  #18746
Default need some help , gonna buy trf 415 marc r
what kind of pitch is orginal , and im gonna use a 4.5 novak brushless system an d which spur and pinion should i use
tomin is offline
Old 07-01-2007, 12:24 PM
  #18747
Tek Nickal's Avatar
tracks.
I believe having short arms in the rear doesn't give the car more steering. Your shortening the camber link, which makes the rear of the car roll less, thus giving more traction to the rear of the car.
Old 07-01-2007, 01:39 PM
  #18748
Super Moderator
Marcos.J's Avatar
i guess the lap counting computer lied to me then
Marcos.J is offline
Old 07-01-2007, 10:04 PM
  #18749
Trader Rating: 72 (100%+)
Gonna have to go with Marcos on this one.
patrick is offline
Old 07-01-2007, 11:20 PM
  #18750
ttso's Avatar
As for my experience, short arm give a quicker response on everything. Traction-wise they are about the same if roll-center stuff are correct, acturally I think short arm generally give less traction than long arm.
IMO, for small, good traction track, short arm is the way. Asphalt, large smooth track, for long arm.
And indeed, short arm seems can take more impact compared with long arm.
ttso is offline
