Like Tree3Likes
Tamiya TRF415
Old 04-15-2004, 09:34 PM
  #1846
jeffreylin's Avatar
Originally posted by F1Junkie
Hi -
I thought I'd ask my question on this forum.
I was wondering if anyone knows the diameter of the ball that goes in the top part of the shocks. I am trying to retro fit a pair on another car and need the part that snaps into the top part of the damper.
If anyone knows the size or has a part number for the pieces I need that would be great.
I am looking for the piece that accepts a 3mm screw to attach it to the shock tower.
Dave
It's 53640
Here:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFSC6&P=X
jeffreylin is offline
Old 04-16-2004, 06:22 AM
  #1847
Turbonium's Avatar
Trader Rating: 27 (100%+)
i am ready to try it too... now, i shoulda ordered another locked pulley for the center already so it would be fully direct drive, but i keep forgetting! plus, when i originally started this, i didnt see anyone had it in stock. now just gotta ring up Steve and order some more stuff........
Turbonium is offline
Old 04-16-2004, 02:59 PM
  #1848
Hebiki's Avatar
Trader Rating: 26 (100%+)
anyone racing their 415 this weekend?
Hebiki is offline
Old 04-16-2004, 03:01 PM
  #1849
JimmyMac's Avatar
Sounds good. I finally get to test my new setup tomorrow in Stock. I'd also like to try out a Strat 2 body as aposed to my Mazda6. But I don't think I'll have it painted in time. Oh well, we'll see.
JimmyMac is offline
Old 04-16-2004, 03:06 PM
  #1850
Hebiki's Avatar
running 3 classes this sunday... stock, 19T and mod... so the 415 will see double duty in 19T and mod. hopefully i get to test the mazda6 with my new set up and tamiya ferrari body also.
kilruf - u using two hole pistons? i switched mine to the 3 hole.. and 30wt associated oil.. hopefully that'll work better because i wanna run a stiffer spring. all the tracks i go to have pretty good to carpet like traction.
Hebiki is offline
Old 04-16-2004, 03:11 PM
  #1851
NVisible's Avatar
Considering picking up this car. Is there any more information on it other than the limited info on the tamiya site?
NVisible is offline
Old 04-16-2004, 03:15 PM
  #1852
JimmyMac's Avatar
I'm running 3hole with 600wt Tamiya oil. I have been running the 400 with 2hole before. But last week the car felt real good with the 600wt. Only problem was it rained before I had a chance to get a qualifier in to get some real lap times. So we went indoors onto the carpet. Had to whip out the Yok SD for that and put up the 415. This weekend looks to be Sunny! I'd also like to try AE 30wt with the 3 hole pistons as well. Plus I'm running Tamiya White Springs up front with Blues in the rear. Anyways.. we shall see.
JimmyMac is offline
Old 04-16-2004, 03:17 PM
  #1853
Hebiki's Avatar
what do you wanan know?
info you should know: no front diff.. spools are available thru speedtech. locked center pulley you have to do yourself. if you want more info.. PM Me.
everything else is awesome about the car...
Hebiki is offline
Old 04-16-2004, 03:18 PM
  #1854
JimmyMac's Avatar
Yeah what he said... haha... beat me to it... Read here or just ask if you have specific questions...
JimmyMac is offline
Old 04-16-2004, 03:25 PM
  #1855
NVisible's Avatar
my main concern is the lack of a front diff. Is it really that big of a deal? id be mostly using it outdoors.
also, hows the hardware it comes with? would i be wanting to get a stainless or titanium screw kit? i know the screws that came with my xxx-s were crap compared to the stainless im running now
NVisible is offline
Old 04-16-2004, 03:35 PM
  #1856
JimmyMac's Avatar
No diff, have to come up with your own make shift deal. I don't need it since it's my outdoors car. But other people need a diff to run foams on carpet or to run the Reedy Race where oneways are banned. Screws... I'd upgrade to Speedtech's Ti screw kit. The kit screws will work. But Tamiya "stock" screws tend to strip out the heads sometimes. Mainly counter sunk ones.
JimmyMac is offline
Old 04-16-2004, 03:37 PM
  #1857
NVisible's Avatar
ok great, thanks alot
NVisible is offline
Old 04-16-2004, 06:53 PM
  #1858
jeffreylin's Avatar
Nah, the black screws that came with the kit are first rate. But I'd upgrade to titanium ones anyway to save weight.
Old 04-16-2004, 10:18 PM
  #1859
JimmyMac's Avatar
You think so? Are they different than the screws that were in the 414? I just remember people stripping them out and having to dremel the screw heads on the 414. I didn't take the risk.. so I'm using Ti screws on the lower deck.
JimmyMac is offline
Old 04-17-2004, 12:44 AM
  #1860
JRRobiso's Avatar
Wink
Actually the kit screws are not bad at all. I too had the same problem when I was putting my 414M together and also dealing with those type of screws for the first time. The mistake I did, I was tighthening the screws way too much that it was impossible to loosen them up with the wrench that came with kit and ending up stripping the heads .
This time I just give a nodge to tighten them down. No more stripped screws.
JRRobiso is offline
