Tamiya TRF415
Originally Posted by Burlap
Does anyone know of a place that might be still stocking the base plate/lower deck for a 415MRE?
RC Champ have sold out, haven't heard back from R10 yet, RC Mart only has the 415MSXX and Speedtech RC has none in stock.
Originally Posted by nino_pohan
Hi, guys. My TRF ball diff have a problem i hold diff joint (L,R) but i can still rotate (loose) the diff pulley i already change diff plate, diff pulley, screw, spring, trust bearing and try to tight the screw but is not work. what should i do? Thanks
Originally Posted by TryHard
Rampal;
No spacer, I just built my car as kit as kit instructions, no issues on that front.
Everyone;
Regarding the servo saver... I've been using a direct link on my car since mid way through last season, when I finally got P'd off with the slop that generates over time with the savers. So far, not knackered a single servo, and I've had some BIG hits (one even broke the chassis, and servo mount screw!). Only issue I have is occasionally, the ball joint pops off, but when that happens I just replace it.
Works for me basically
Wet setups.... if it's fully wet (ie standing water) raise the ride height, stick on some D20 wets, jobs a good un.... D20 wets generate more grip in full wet than just damp.
If it's damp, look into changing your springs and droop, or just simply lay down your front shocks, and stand up the rears. I've always found that in damp conditions, your forever looking for steering, so running a softer front spring, or even a one-way can be a good option.
Oh, and I've attached a pic of my car waterproofed from last season... full standing water, and the car just kept going... MRT's are awesome!
HiH
Ed
Everyone;
HiH
Ed
anyone knows 415msx mre ver centre direct shaft will fit in 415msx chasis or not?
RE: 18t pullys!
Originally Posted by TRF415boy
I have been running an 18T centre pulley for the past year and a half...
So can you run the belts looser with the 18t? Have you noticed any difference in freeing up the drivetrain?
Tryhard,
I'm running the MRE cnter in my MSX but I had a hard time finding the E clip that holds the plastic gears in place. Had to buy the screw bag kit that had the e-clip.
It cost me $30. So, now I have lots of extra Titanium screw to go with the clip!
So, are you going to watch the Liverpool vs. Milan game. I'm going to watch it now on ESPN 2. I think it's live? Who do you think will win? I'm pulling for Liverpool, I believe they are the underdogs since they are playing in Greese, right?
Max
Originally Posted by maxepower
TRF415boy,
I don't know if you can run them looser, as I never run my belts very loose. One reason is that I don't run stock, and the other is I don't like the feeling with loose belts.
For me the major advantage is that there is a LOT less wear on the pulleys and belts. I have ran the same rear belt for now a year and a half, and the front belt lasted me a whole year. I have never snapped a belt ever since I went to 18T pulleys, where I was snapping belts all the time before. The drivetrain is free there is no problem with that.
RE: 18t pullies
TRF415boy,
If running the 18t means no snapping off belts than thats reason enough for me to try it! Are the MRE belts long enough to work with the 18t pully?
Liverpool lost!
Liverpool lost!
TRF415boy,
Liverpool lost!
Liverpool lost!
Originally Posted by Tsquare
If the diff lock nut is not able to be fully tightened because it is turning inside the diff locknut holder ( I have had this problem in the past), use a small amount of CA glue to secure the locknut to the diff locknut holder. I do this everytime I rebuild a diff, have never had a problem since.
R/C Tech Elite Member
I'd give the diffballs a go, I don't see how the outdrives could cause it unless the retaining nut isn't sitting in right, have you done the thrust bearing?
Is anyone else having a hard time accessing the precision-rc site? Trying to buy a spool and diff covers, but I get as far as registering, but can't check out.
And on that note, would anyone know where I can find the JAAD spool and diff covers in the U.S.?
Originally Posted by tamiyarcracer
TamiyaUSA.com has them, so I'm sure Speedtech can get you one if you ask for one.
Which car is this diff from? is it the aluminum one? because if it is and you have changed almost everything and are still having the problem check to see if the 0.5mm shim that goes inbetween the bearings in the diff is still there.
