Like Tree3Likes
Tamiya TRF415
Old 08-30-2006, 07:45 PM
  #15421
Originally Posted by drew85
I heard there is something that had to be filed down on the MR car, like block?? true...
Yes...2 areas...
1st the delrin outdrives for the spool
2nd, the most painful, the blue alu steering parts...
This is the 1st time, I've got to shave metal off....!
Ben.C is offline
Old 08-30-2006, 07:53 PM
  #15422
drew85's Avatar
Why does something hit?
drew85 is offline
Old 08-30-2006, 08:30 PM
  #15423
The edges cliamed by Tamiya will hit the belt. So they say its safe to shave a little off there...
Ben.C is offline
Old 08-30-2006, 08:49 PM
  #15424
Turbonium's Avatar
Trader Rating: 27 (100%+)
its talking about the steering arms, they can get very close to the belt.
i havent filed mine yet, i figured id look after a few weeks, and see if it is rubbing. nothing after 2 weekends of running...
Turbonium is offline
Old 08-30-2006, 10:04 PM
  #15425
Darnn...!! I've done all those shaving and grinding for nothing?!~
By the way, does the TA05 centre and front one-way fit the MRE??
Ben.C is offline
Old 08-31-2006, 05:49 AM
  #15426
kewdawg's Avatar
Originally Posted by xtrememadness
rick is correct. i just checked my 4mm chassis and the new steering rack wont fit. i agree with carl you dont really need the new rack on the rug. i got alot of slop out of my msx steering with a couple of shims. if you run 7 turn mod motors like mark r you could probably use all the steering you can get. i only run stock and 19t and i have more steering than i need. just my $.02 cents.
xtrememadness,
What carpet tracks you are you racing at? If, Horsham R/C is one of them, when will you be going there? Maybe, we bounce some ideas off of each other?
kewdawg is offline
Old 08-31-2006, 05:59 AM
  #15427
TryHard's Avatar
Still, prefer to know that mine won't hit regardless
And No the neither the TA05 front or centre one-way will fit. Centre one-way won't as the belts are the other way round (Front belt is on the right on the '05, on the left in the 415), and the front oneway is also offset to the right, and not central.
HiH
Ed
TryHard is offline
Old 08-31-2006, 06:01 AM
  #15428
kewdawg's Avatar
Originally Posted by TryHard
Jay,
It was the HPI / HB arms for deffiently. Basically, the arms are have the pin holes closer, which is ment to be better on carpert (one of the reasons why most of the TRF team liked to use the old 414 style suspension on carpet).
Now, given Tamiya have released the short arms... which are 0.5 and 1 mm shorter than the std LWT arms, and 0.5mm longer (at the pin holes) than the HPI arms... coincidence, doubt it
(HPI arms F= 53.0mm, R=53.5,
Std LWT F=54.0, R=55.0,
Short LWT F=53.5, R=54.0)
HiH
Ed
TryHard,
What's the part number on the new Short LWT arms?
kewdawg is offline
Old 08-31-2006, 06:29 AM
  #15429
Carl Giordano's Avatar
Trader Rating: 32 (100%+)
Originally Posted by TRF415boy
I wouldn't think you'll have enough belt tension by dropping a whole 3 teeth on your pulleys. I'm using 18T pulleys with the TA05 diff/one way pulleys and longer belts to good effect, especially in terms of lifetime of the belts and centre pulleys.
I'll know this weekend...someone asked why I'm looking into this...my response
Does this make sense for you guys...keep in mind I'm racing carpet foams on an tight twisty track...you feedback is appreciated.
This is what I was thinking.
> figure the same 56mm tire size and 102 spur...to get to a total roll-out between 28.3-28.5, probably good for stock on this track
> with 32T diff gears, internal ratio is 2.00 you need a 33 pinion to get roll out of 28.460
> with 35T diff gears, internal ratio is 2.25 you need a 37 pinion to get roll out of 28.364
> so I figure the smaller pinion would give better rip off the corner...not sure if this is true...which is why I asked
If you notice the 35T gears were first seen during the worlds for modified racing.
Carl Giordano is offline
Old 08-31-2006, 07:19 AM
  #15430
TRF415boy's Avatar
No it won't change anything, you'll still have the same rollout so same acceleration. To be honest I would use the 35 or 36T pulleys as they'll definately provide better efficiency. The 35T pulleys were first seen on the 415, 32T pulleys were for the 414 series only. Since the very low winds motors started to be used they started using 36T pulleys to have a better gear ratio range, but they also have better efficiency due to less belt wrap.
TRF415boy is offline
Old 08-31-2006, 07:24 AM
  #15431
Charles Godwin's Avatar
Default Cotswold
Went for a little spin today at Cots, ended up on 4.7 on my atlas (blue can) and a one-way . Felt ok, just needs some more turn in
Charles
Charles Godwin is offline
Old 08-31-2006, 07:28 AM
  #15432
I agree with your point with respect to the efficiency...something I was concerned with as well...However..the roll-out method is basically a measurement to determine how far the chassis will roll with "1" rotation of the motor. Therefore..."1" full turn of the pinion gear = the chassis will roll 28.5 mm.
So, if you have a smaller pinion..in theory it should enhance the acceleration of a corner...
Real problem I'm having is the lenght of the belts and the most important fact...the white pulleys look too cool.
Old 08-31-2006, 07:40 AM
  #15433
TRF415boy's Avatar
That's a misconception, if the rollout is the same then it doesn't matter how big your pinion is you'll have exactly the same acceleration as it is uniquely a function of the rollout (assuming we're not changing the efficiency of the drivetrain, which you're doing with your 32T pulleys but in a worse way IMHO).
Old 08-31-2006, 08:22 AM
  #15434
axle182's Avatar
Trader Rating: 18 (100%+)
Any gains you make on a smaller pinion are squashed by a smaller diff gear, so if the ratio is the same, then no difference in acceleration. As TRF415boy said, you'll gain more in efficiency with the bigger pulleys.
Only reason for changing internal ratios, just so you can use a smaller pinion, is if you using super heavy steel pinions, which im sure your not. the smaller pinion would weight less, which means less rotating mass = better acceleration. The difference in weight of the small pulleys vs the large ones, is basically nothing, so theres no gain in smaller pulleys. Belt efficency would be way more important that rotating mass in this case. well thats the way i see it anyways lol
axle182 is offline
Old 08-31-2006, 08:44 AM
  #15435
Trader Rating: 14 (100%+)
Carl:
Hi,
I agree with TRF415boy. if the rollout is the same pinion size won't matter. I wonder about the internal ratio of the car though. it seems a higher ratio would be better for stock (everything else being he same). our best stock sedan has the highest internal ratio. having just bought a 415MSX to run on carpet/foams. I have been looking at the TA-05 diff and centre gears for my 415 to raise the internal to 2.25.
also do you guys cut the fronts down at all or just space them out???? I ended up spacing the rims out about .040
so thet won't rub. or do you use a different steering knuckle???
(this is my first Tamiya besides my TA-05. I'm trying to get it ready for Cleveland)
TimXLB is offline
