Tamiya TRF415
Whats the diffrence between the RD 0.4 pinion, steel 0.4 pinion and just a 0.4 pinion?
hey
is there any were i can get a compleate ta05 pully conversion for the msx front and rear diff pully plus one way pully and layshaft compleate kit.
you guys were talking about belts ive had the msx for about a year i.m changing belts once twice a month ive had four fixed centre pullys ive even gone to the orignal black belts to be blunt they are pretty shit if you ask me i ran i yokomo before the msx and never replaced a single belt and no they are not too loose.
stu r
stu r
Originally Posted by TacticalTimbo
It might not be the standard way of doing it, but really whats so bad about Velcro? I migt even use it instead of double sided tape this time to stick the radio gear down. I mean the amount of times I had to rip the radio gear off my last chassis for one reason of another, wasting tape & putting extra stress on it.
Originally Posted by Guo Chean
anyone have the instruction manual for MR edition? thanks
http://www.arroyoc.com/rcracing/msx_mre.pdf
is the only difference between the MRE msx and the regular MSX the steering set up?? i know that it comes with the Mazda 6 and Marcs signature on the motor mount. but is there any thing that much better?
hey guy speedtech was selling MR edi only 409 USD only
Originally Posted by stuey
hey
stu r
stu r
Originally Posted by nordheim
The car is significantly different when it comes to the guts but yes, mostly is due to the steering. There are other differences too though.
Originally Posted by Smoking motor..
i am confused about the more steering i have to set my end points to get 20degrees of lock left and right and i am turning the max throw down still. YEs more steering will make it turn tighter but do you really need to kill your servo so quickly?
In the name of FAST.... YES...!!
No....just kidding...There are lots of ways to get more steering...The 415 has tonnes of setup options to get the steering you want without killing your servo .
Steering setup, very similar to the Evo5, but with a vertical ball stud on the cross beam. Also means different chassis plate (with holes cut for a cooling bracket, and other suspension block holes), and top plate.
Different pulley setup. Similar to the TA05, except the pulleys have every other teeth removed, and are a slightly different pitch to the standard TA05 ones. Also there is a protective lip on the diff pulley (unlike on the 415/05 ones which are open)
Centre pulley. Now uses alloy brackets, which allow up and down adjustment of the spur gear (allowing bigger spur). Also the centre mount is one-piece, with no seperate layshaft. Much lighter than before.
Rear Alloy top brace. Heat sink design.
Rear hubs. Less play, and 0.5mm lower. I didn't notice this until someone (ta Mr Maddison) pointed it out, but the rear hubs are different. easy to spot as they are marked H0.
All in all, a fair few changes, and with the new steering setup, highly unlikely to be a conversion kit.
And on the Belt thing... I run mine seemingly quite loose. Never have a problem with skipping though, which is what I've always been told. Run them as loose as possible without skipping. Anything thats tight will wear faster than something thats loose... simple fact.
When I push down on the front belt just behind the front pulley, I can touch the top deck easily, and the rear is similarly loose.
That was with the old white belts. Not done enough running on the new setup to tell how these fair.
Ed
Do you mean the Axle height is 0.5mm lower??
Thanks,
Originally Posted by Eirik
Hey Ed,
Thanks,
Thanks,
