Conrod in D5 interchangeable with the s5 or s3?? >
Old 10-30-2003, 08:53 AM
Default Conrod in D5 interchangeable with the s5 or s3??
Anyone know if the STS d5's conrod is the same as the ones in the ns12s3 or ns12s5? Thanks.
G
loosenut is offline
Old 10-30-2003, 09:03 AM
eddiethefish's Avatar
Default Re: Conrod in D5 interchangeable with the s5 or s3??
G
Yeah, I encourage you to replace the D5 conrod with the NS conrod. It's been proven that it's interchangeable, and it will not break in half when reving it fast. Right? DATA?
eddiethefish is offline
Old 10-30-2003, 09:24 AM
Default Re: Re: Conrod in D5 interchangeable with the s5 or s3??
Etf:
I highly recommend you stop leave your comment until you return my receiver.
Best Regards
rdlken is offline
Old 10-30-2003, 09:36 AM
Default Re: Re: Re: Conrod in D5 interchangeable with the s5 or s3??
Originally posted by rdlken
Etf:
Best Regards
if someone would just show up as promised.
Data's Avatar
Etf:
Best Regards
Data is offline
Old 10-30-2003, 09:38 AM
Data's Avatar
yes, but still need to use the D5 wrist pin. the hole on the piston is slightly smaller, can not use NR wrist pin.
Data is offline
Old 10-30-2003, 09:54 AM
wrist pin....that's something that you don't need to change right? Sorry I've never changed anything inside of an engine before. I guess what I'm trying to say is - the wrist pin is reusable right? I'm planning on ordering some novarossi conrods both for my novamax and my sts d5.
G
loosenut is offline
Old 10-30-2003, 01:11 PM
it could be reused just have to check it for wear..but i highly recommend putting a new in..i mean they are only a few bucks and could save plenty of money..
2mcgrath is offline
Old 10-31-2003, 04:58 PM
smartdriver's Avatar
Eddie,are you talking about the Dragon 5pt by STS?
smartdriver is offline
Old 10-31-2003, 05:24 PM
Yes, the one and the only one STS 5-port Dragon...
Use its original con-rod to break-in engine. Then, replace it with Novarossi con-rod before running. Voila! vrooooooooooooommm...
Old 10-31-2003, 06:47 PM
Manticore's Avatar
the D5 conrod is made out of 7075. it is just the copper bushing wears during run in process and the factory recommend to replace the conrod right after run in.
the original conrod on my D5 has gone thru 1 gallow of fuel (including run in) and there is no obvious sign of wear. I replaced it when I did "special treatment" to the D5.
Manticore is offline
Old 10-31-2003, 08:11 PM
EVOLUTION's Avatar
I think I have to message you to find out what kind of special work you've done MR TOM?
EVOLUTION is offline
Old 10-31-2003, 08:26 PM
Manticore's Avatar
that's easy, use WD40 and KY !!
Old 10-31-2003, 09:04 PM
Yeah after talking to Dino from STS, apparently teh conrods in the Dragon series are updated and it's recommended to replace the rod after break in....but it's good that it's interchangeable with teh novarossi's....
G
loosenut is offline
Old 11-01-2003, 07:03 AM
Default NS12S5 con rod
Anyone know where I can purchase this S5 con rod in US? Thanks.
V1RR is offline
