HB cyclone S kit rear toe???
I am pretty new to RC and I have a question about the rear toe on my car
The car is all together now, but when I look at the rear wheels they seem like they tilt in towards the front of the car (excessivly), I am not sure if this is normal or not
If it isn't normal how would I go about adjusting this and would I need any parts
the car will primarily be used for street driving, rubber tires and maybe some racing later
Mike
Mike
it depends on which toe block you use. i believe the rear stock block is 3.0 (toe in). you can adjust this buy purchasing different toe blocks but if you use the aluminum ones, you're going to need these..
pivot ball ends
http://www.speedtechrc.com/store/ebp...id=471&id=1448
along with some sort of spacers like these
http://www.speedtechrc.com/store/ebp...id=471&id=6075
http://www.speedtechrc.com/store/ebp...id=471&id=7974
http://www.speedtechrc.com/store/ebp...id=471&id=6095
aluminum toe blocks here..
http://www.speedtechrc.com/store/ebp...?catmainid=475
pivot ball ends
thanks for the reply, I get everything you are saying
the only thing would be, how much toe am I looking for, or what would be optimum for what I want to do, mostly playing around outside, maybe some racing later on
Mike
Mike
