Help TC3+ MOD
Help TC3+ MOD
New to nitro picked up a used TC3+ and would like to widden the wheel base and gain a little ground clearance with some bigger tires.
Using some exstensions or whatever it takes I know it sounds a little crazy but where theres awill theres a way.
If exstensions will work I will probably have to go with a rear exhaust after looking at it. With the wheels turned all way left I only have about 3/8 of an inch clearance between tire and pipe. With the way I am thinking of I can go back and forth with the way I drive it.
I'm sure theres somebody out there as goofy as me that has tried it.
anybody with pics of a ntc3 converted to a LMO (late model outlaw) the 4whl.dr
I have one, and thats exactly what I want to do to it.
Mostly I want wheel spacer sizes for bigger tires and thus more ground clearance
Not sure on what you are talking about but I put 1/8 scale Mugen wheel/tires on my old NTC3 along with a .21 that I fitted and this car was a ROCKET. It was more of a fun car since there's no more 235mm classes around anymore.
http://uk.youtube.com/watch?v=FW03UZ41GtU
thanks for the reply, what I'm looking for is what is needed to get the chasis higher of the ground, only way I can think of is longer axles to get tires away from the chasis and then I can put bigger ( taller tires on it which will bring the chasis higher. after looking I dont think spacers will do it, it will have to be longer drive axles
example
here's what I have in mind I cant remember where this pic came from or what car it actually is but it looks like a NTC3 and even if its not it more explains what I'm trying to do
NTC3 MOD
I can and will convert it!
I just want to be able to run it on a dirt flat track or in the grass if I want to.
I dont have the money to go out and buy that exspensive toy.
I got the NTC3 in a trade for some HO trains that I had $75 tied up in.
I will post pics once I get it done to prove your wrong!
The bigger tires will give me the clearance I want.
Some positive input would have been nice.
Heres a conversion for the electric tc3...Maybe it will work with a nitro version...I thought about building one but I have`nt gotten around to asking the manufacture of this conversion if it will work with the NTC3..
http://www.rcproductdesigns.com/TC3_O_%20index.htm
