Serpent 966
Old 10-12-2010, 09:19 PM
  #1291
Do the GRP rims and tires fit the 966. Do I have to shim anything?
joe hose is offline
Old 10-12-2010, 09:23 PM
  #1292
Pattojnr's Avatar
Trader Rating: 19 (100%+)
they do fit, but remember they are wider on the rear, so you will have to adjust your track width, and you will have more rear grip, so you will loose some steering as a result.
Pattojnr is offline
Old 10-12-2010, 09:41 PM
  #1293
Do I have to adjust the track width to make them fit
joe hose is offline
Old 10-13-2010, 01:06 AM
  #1294
M7H
M7H's Avatar
With the GRP tires the most narrow setting on the rear will be 267mm (atleast, on my 966)....
M7H is offline
Old 10-16-2010, 07:27 PM
  #1295
bobbyblaze's Avatar
is the aluminum radio bracket & front filler plate good to have?
bobbyblaze is offline
Old 10-16-2010, 08:22 PM
  #1296
captian's Avatar
Yes they are good to have
captian is offline
Old 10-16-2010, 09:40 PM
  #1297
bobbyblaze's Avatar
thanks captain...adding to the wish list...lol
Old 10-16-2010, 10:14 PM
  #1298
captian's Avatar
Any time
captian is offline
Old 10-18-2010, 06:49 PM
  #1299
Default GRP
Joe put the rear tires on your tire truer and cut off about 2mm off the inside use an exacto knife or hack saw blade . i used the exacto knife cut through the foam then the rim . use saftey glasses . done already works fine you will then be able to get your regular track width and tires will be close other brands width since the grp were wider to start .
Richard Siriano
brooklynhobbies.com
nyrclive
team mugen northeast
TEAM BROOKLYN is offline
Old 10-20-2010, 08:34 AM
  #1300
966 is The ROAR region 9 Champ!
J-MAN is offline
Old 10-20-2010, 01:04 PM
  #1301
captian's Avatar
Congrats on your win in texas and roar champion
captian is offline
Old 10-21-2010, 07:28 AM
  #1302
tl2111's Avatar
Trader Rating: 21 (100%+)
Is anyone having same problem like me, the chassis has massive tweak when I put the radio tray on, without the tray chassis sit flat on the setup board
dont think is the chassis cause I have took front and rear end off to check, it seems to me the front bulk head is not aligning to the tray hole is bit off.
tl2111 is offline
Old 10-21-2010, 08:14 AM
  #1303
I've never had that problem. Check radio tray mount. If it still gives you the tweak, try the aluminum radio tray mount with new bulkheads.
nitrodude is offline
Old 10-21-2010, 08:21 AM
  #1304
Geezatec's Avatar
Either try turning your servo around 180degrees; relocate the carb position, Or may your EPA on your radio is set to far, lessen your EPA.
Geezatec is offline
Old 10-22-2010, 01:19 PM
  #1305
You can try and use the aluminum radio tray bracket.
yappy is offline
