Serpent 966
#451
This car was produced via careful and precise measurements. There is no need to alter or modify any parts to make it work..on the other hand, we all have to remember that we are working on these a lot smaller scale cars that are as close to working on the real race car . That your hand would apply torque gently, meaning..let the loctite do its work...Now in regards to setting up, I ask the more knowledgeable racing buddies around..I am learning the car as I go.
This is a very good car and I hope that prices for the parts will remain affordable
Last time I checked..this car has been on the winning podium lately
#453
Also finished my yesterday off to track tomorrow....
A few bits were missing from the kits...but managed to borrow off a 960 08 which i brought on ebay as a spare !!!
First time testing tomorrow as we got the first nationals of the season this weekend in UK!! let see how this handle and response compared to my mrx4r
#454
#455
Hi guys,
I sent an e-mail to several of you that were willing to know about my experiences with the car. I will post that same info here, just so people that don't feel to send me an e-mail will be able to read the info.
Shocks: soak the foam with oil before building. Fill the shocks until the first thread. I found a good and technical way to make sure the shocks are equal. I use caste clips. Basically I put caster clips in the shaft. So after no more air is in there, pull the piston and install the caster clip (I use 5 mm caster clips for the rear shocks and 4 mm for the front) Screw in the shocks (couple of turns) Then start pushing in the piston all the way down (the caster clip is going to limit the travel). With the piston in this position, screw all the way in the plastic parts. After this remove the caster clip. You will end up with a shock that is super Smooth thru the whole travel with a almost a 50% rebound. If you want less rebound, go 1 mm less clips (both front and rear shocks
Setup: This is what i was using as starting point every were. I will say with this my car was 90%. The rest was just small adjustments depending on track conditions
Front
Downstops 0 (really bumpy track -1)
Sway flat
Car long
Roll center: 1 mm under upper arms and pins inside.
Caster 2 mm in the front
Ackerman: narrow/in
Schocks: 3holes 40WT (1000cst) or 45WT (1400cst). Green springs and 1st position on tower. Stock springs works too but are softer
Wheel scrub: 1 mm inside
Toe: 3 total
Camber: 1.5
Steering blocks: # 2 on the right side
Wheel axle pos: up (sometime I like in the middle) I use just a big bearing for this
Ride height on hudy setup station: 8 (really bumpy track 9)
No under chassis stiffner
Rear
Downstops 6 (really bumpy track 5)
Sway Flat, outside
Car long
Roll center: lower pin all the way up. Upper arm inner hole in the bulkhead, middle hole in the upright, with 2mm spacer
Schocks: 3holes 40WT (1000cst) or 45WT (1400cst). Pink springs and 1st position on tower. Stock spings work too but are softer
Wheel Scrub: 0mm inside
Toe: 2.5
Camber: 3.5
No side stiffner on the right. Left stiffner not screw it in the rear bulkhead (I cut mine so it hold only the belt tensioner) but I have extra in case I want to use it in a specific condition
Ride height on hudy setup: 9.5 (really bumpy track 10.5)
Body position; Whit Zytec I use upper hole in the upright (body mount arm) and second hole from the outside in the body mount Attention: Make sure that you move the bodymount centering shaft if you decide to lower or raise the body. You have 2 holes in the shock tower.
Clutch:
flyweights pivoting against the rotation of the engine Gap 0.8 End play 0.3. Under extreme low traction condition, go to 0.6 gap and 0.3 end play.
Preload: 1.2
Gears:
Low bite: 16-48 / 19-45
High biter: 15-47 or 48 / 19-45
This is the setups I was using. This weekend I made several test and I found a better compromise. Below the changes (whatever is not there I used the same as above)
Front
Roll center: 0 mm under upper arms and pins inside.
Shocks: 1 holes 800 CST with green springs 1st hole
Camber : 2.5 outside 2 inside
Steering blocks; #1 on the right and #2 on the left
Wheel axle: Middle (I use a big bearing)
Rear
Shocks: 2 holes 800 CST with pink springs 1st hole
The car was very good with this setup. I used same shore tires front and rear
Hope this info can help
Front
Sway flat
Car long
Ackerman: narrow/in
Toe: 3 total
Camber: 1.5
Rear
Sway Flat, outside
Car long
Toe: 2.5
Camber: 3.5
Clutch:
Preload: 1.2
Gears:
Front
Rear
#456
they make those for the 08 /09 car i have never see them in aluminium???
#457
Oh yeahh...
kenna weyt to run my car no moh..I'll be there friday to break-in an engine and practice
#458
what a car !!!
Hi all,
Nice sunny day at the track apart from tail back on the motorway due to strike in France.... but UK was affected as trucks not on ferry !!!
THE CAR WAS EXCELLENT.....it went where i want it to go. The steering was so precise...no understeer or oversteer !!! The back end was planted....it was like scaletrix (not sure spelling !!). was running till front tires had about 5mm of foam and it still work. Was plan to run in my sirio AAC b4 nationals but too much fun that i forgotten.
Used the set up by Paolo M but standard springs and shocks as supplied in kit.
Thought my mugen mrx4r was easy to setup and drive....this car is a different league altogther.
Word of advice...use threadlock as i forgotten on rear axle that connected to rear bulkhead and only go half a rear belt left as it was split in half !!!!
#459
sorry forgotten to mention....the car was amazing through the techinical part (see google map satellite uk type in tn29 9tf to see track)
#462
Upgrad to 966 question
Hey guys. I still have the original 960. Can this be upgraded to the 966? Everything I have read says you can go from an '08 to 966. Just thought I'd ask. Thanks
#464
i am actually in the process of upgrading my original 960 to not-so-full 08 spec and most likely sometime in the mid season i'll convert it to the 966 spec.
upgrading to the 08 spec, you have a choice of either OS1 or OS2. OS1 uses Serpent wheels, and OS2 uses Mugen/Kyosho wheels.
from what i've read so far, the chassis is not necessary to get the 08 spec, when it's time for me to do the 966 conversion, the 966 chassis is part of the conversion kit.
hopefully my explaination is clear, if you need a list of parts for converting your original 960 to the 08 spec, let me know and i can list them out for you.
#465
