How do you plug this ps into a wall socket?
#151
The switch is simply for the fan in the battery cooling station. I have two other fans connected to the power supply that automatically turn on when the power supply is plugged in. If you notice another plug (not connected) hanging off the outputs of the power supply, that is used to connect to the fan in my TC3 foam stand. So I am powering a total of 4 fans and my charger from the power supply. I gotta get a better AC cord (one with a ground).
#152
fans
i was thinking of trying one of those thermal controlled fans that turns on when the ps temp strarts to go up...
#153
I have one question though. I am just using the +V and the -V for outputs. Shoud I use the +V+S and the -V-S instead of the +V and the -V? Every thing works fine how I am using it now, I am just wondering which to use (if it matters). And yes, I under stand all the +S and -S meaning "Signal".
Thanks,
etzkev
Thanks,
etzkev
#154
Re: fans
#155
Thanks,
etzkev
Thanks,
etzkev
-dave
#156
The pictures look great guys
Please. Soon.
-dave
-dave
#157
No, you don't understand. I have them in the single wide V- and V+ terminals. Not the double wide ones. Is there anything wrong with that? Thanks for all your help.
#158
Re: switch
whats is the switch for and how did you connect it?
#159
-dave
#160
OOOOOH! Ha ha I see. Thanks for the clarification.
#161
Please. Soon.
-dave
Please. Soon.
-dave
#162
well, just ordered One Of these. from things im hearing should be great supply. I will be running 1 iron and 1 charger. Dont know if will hold If not just a charger. Hope i get it soon im excited.
#163
Well, what charger are you using?
#164
just a novak millenium pro, iron(HAKO 936 i think)
#165
Oh, haha, well then you will be fine. You probably can use two milleniums AND your iron.
