Best Rubber tires
Best Rubber tires
Hello
Those brands of rubber tires which is the best for asphalt.
Brands: CS , RP , Much Moore, LRP , No mark(top Racing) , Sorex.
Thanks in Advance.
Best Regards.
Pedro Silva
Thanks in Advance.
Best Regards.
Pedro Silva
Sorex all the way. 28s and 32s I find work in most normal temps
Jaco 26s 32s
i really like sorex
Had great results with Sorex premounts outside on asphalt. And good results with Jaco's on carpet. Never was happy with the Jaco's outside but they could not be beat on carpet.
Tony
Tony
I find the Top 36s to be quite a good tyre.I 'm running them with an 07 T2 in 540 silvercan.They get up to temp pretty fast and carry good corner speed.Wear is great too.The only thing i dont like though is the rims,they are brittle and crack easily.
Suspended
Sorex 28's FINAL ANSWER.
mrrcguy, If you buy them from RCMART there not glued, but there cheap low $20 range. At least this was that case when I bought some back in September of this year.
Sorex have been the best tire for longevity but my first experience with Much More Sweeps was a very good. You just need to use them in their list temp range or they'll wear very quickly. For the money thou they may be my new tire of choice this next summer for outdoor racing.
Typically sorex 24 and 28 will cover me indoors and out, unless the outside temperature is really really low,(0degrees C ) then I might use cs22's
Sorex in track
RP in no trackion are best !
