What is The Best Auto Tire Truer >
Old 10-16-2003, 08:17 PM
rcfoolz's Avatar
Trader Rating: 22 (100%+)
supprized nobody said anything about the cobra tire truer.
rcfoolz is offline
Old 10-16-2003, 09:18 PM
By the time I am halfway through my warmup the "roughness" from my saw blade cut is as smooth as a new tire.
kreidel is offline
Old 10-16-2003, 09:24 PM
AMGRacer's Avatar
Right you are. I finish my tires with a file and sandpaper anyway so they turn out to be just as they were from the box.
AMGRacer is offline
Old 10-17-2003, 03:41 AM
stefan's Avatar
EXACTAMENTE
I have never seen a less expensive tire truer ruin a pair of tires and the motors usually break only when people try to take 5mm rubber off on a 45 shore in one pass.
There is a lot of areas, where I would really spend the money for Hudy stuff (comm lathe, hand tools) but not a tire truer, which is a relatively crude apparatus
stefan is offline
Old 10-17-2003, 05:13 AM
  #20
rcfoolz's Avatar
I use a cobra truer and I turn down bsr cap tires on it, its hard rubber, but I only turn it down .1 or .2 mm for putting stager in them, but it doesn't even bog it down.
For the foam rubber, 45 shore it just rips off 2 mm like it wasn't even there.
rcfoolz is offline
Old 10-17-2003, 06:08 AM
  #21
vtl1180ny's Avatar
I have the cobra, it takes me numerous passes to true down brand new foams from the roughly 65mm to 60mm... I'd ike to have an automtic machine that would do it quicker, but it just isn't in the budget... Anyone have any suggestions to make this macine cut quicker???
vtl1180ny is offline
Old 10-17-2003, 08:41 AM
  #22
rcfoolz's Avatar
I took the cutter and bent it into a "V" shape where the tire contacts it.
rcfoolz is offline
Old 10-17-2003, 08:55 AM
  #23
Racer4Life's Avatar
Trader Rating: 21 (100%+)
It all comes down to how much you can afford for a truer. All that have been talked about will work just fine, but it depends on what you want to spend!
Racer4Life is offline
Old 10-18-2003, 07:19 PM
  #24
Registered User
Max Mod Truer, bought it 2 years ago. Not auto, but all you would ever need.
bbntc3 is offline
Old 10-23-2003, 08:39 PM
  #25
xxxgrumpxxx's Avatar
Do you have a link for the max mod and cost? Anybody else used this truer?
xxxgrumpxxx is offline
Old 10-25-2003, 07:42 PM
  #26
MattSSG's Avatar
Does anybody have the Team Integy Team Truecut tire truing machine P.N22306? Is it a good truer and what diameter of tires will it cut (in mm)? Thanks.
MattSSG is offline
Old 10-26-2003, 05:33 AM
  #27
Registered User
No link for max modd motorsports. But.. heres a phone# 626-359-7737. Don't leave a message on the machine wait and call around 9 or 10 PM Pacific Time.
It's a second job for them and they work at night. Truer is very compact and has a very strong motor and cutter. I have no trouble cutting the hardest foams. And he has all the adapters for what ever your needs. Priced around $180 with adapter and 12 volt motor
bbntc3 is offline
Old 10-26-2003, 03:49 PM
  #28
CraigH's Avatar
bbntc3-You have any pictures of the MaxMod?
CraigH is offline
Old 10-26-2003, 04:40 PM
  #29
Thank you for the info, I will have to give them a call.
