SMC 40C+  C-Max 7.4V Hardcase Lipos >
Old 07-10-2009, 12:24 PM
  #406
RC MARKET's Avatar
Trader Rating: 12 (100%+)
40C 4700 hard case not fit XRAY 009 in Li-Po balance weight !
because longer 1mm .
& we had Black case !
Attached Thumbnails SMC 40C+  C-Max 7.4V Hardcase Lipos-smc-40c4700hcx200.jpg
RC MARKET is offline
Old 07-10-2009, 04:30 PM
  #407
Sorry for hijacking the thread.
I have 3 brand new smc c-max availabe for sale. $107 each shipped. $300 for all 3 packs.
http://www.rctech.net/forum/r-c-item...-new-sale.html
I am also interested to trade for a new in box sirio xxx s12. thanks,
silverM3 is offline
Old 07-11-2009, 03:55 PM
  #408
Benzaah's Avatar
Trader Rating: 24 (96%+)
Can any Xray users please confirm or deny if these new 40c 5200 packs will fit in the 008 or 009 xray with the new lipo weights attached. Im just about to drop some hard earned on these packs but if they wont fit then im up shit creek.
Benzaah is offline
Old 07-12-2009, 03:03 AM
  #409
Nuno Gancho's Avatar
With the new weights of xray it will fit with little pressor on the side weights, there is no problem.
Nuno Gancho is offline
Old 07-16-2009, 01:50 AM
  #410
Benzaah's Avatar
For those like me who have been asking about the SMC lipos and the Xray lipo weights.
It is a really tight but it does fit!
Benzaah is offline
Old 11-10-2009, 04:48 AM
  #411
Coldn's Avatar
Recently I sent one e-mail to SMC
Hi,
I’m a Brazilian Pilot and bought a Lipo Marck Rheinard Battery of 4700mah 40C, I use it for races with Stock 9.5T LRP engines, certified engines by LRP in Brazil.
Well, I’ve been having some issues with this battery, it starts to swell after 5 minutes race. This month began the LRP modified Championship, I use the 4.0 Engine and the battery swelled so much that opened the hard case, after chilling, it turned to normal size.
Here, I use rubber tires, Esc LRP SXX and engine 4.0T, usually the room temperature is between 26C (80F) and 35C (95F), to compare, I have batteries, LRP 5300 28C, IP 5000 40C and Tune-up 5000 30C.
I would like to know, what should I do? Should I send you the batteries for analysis or something like that? I Bought the Battery at RC-Market store in 05/09/2009
I appreciate your kind help,
Thanks and regards
With no awnser. I dont know what I have to do.
Throw it away or wait for some body to help me.
Coldn is offline
Old 11-10-2009, 06:44 AM
  #412
lutach's Avatar
Esses malucos usa esta propaganda de C rating para atrai pessoas. Tem baterias baratas que parece ser melhor. Estes caras e o da Max Amps vao despencar bonito. Esquece SMC e ver o que o pessoal do rceletrico.net esta usando com sucesso. Desculpe se o Portugues meu esta mal, muito tempo de America faz isso.
lutach is offline
Old 11-10-2009, 08:00 AM
  #413
Coldn's Avatar
opa!! tudo blz Lutach? na verdade eu ja uso o Rceletrico. sou o moderador de la, Cold Fusion!! hehe
mas vim postar aqui pois queria que alguem da SMC fala-se comigo, pois acho um absurdo uma bateria com esse nome ter esse tipo de problema.
Hello man!! how are you? well, I use the Rceletrico, I am Moderador of there, Cold Fusion!! hehe
but, I'm here because I think it is non sense, one battery with this name having this problems with 10 days of use
sorry my bad english.. rssss... your portuguese is good enough to understand.
Coldn is offline
Old 11-10-2009, 08:10 AM
  #414
Perhaps the email did not reach Danny. You said you sent it once....maybe try resending it. I will ask Danny if he got it. SMC always stands behind our products so there should be no concern on your part.
Jack Rimer is offline
Old 11-10-2009, 08:19 AM
  #415
lutach's Avatar
Nice...I like rceletrico. I'm trying to get a couple of guys to put this C rating "or over rating" to a hault. There needs to be a new way of safely rating lipos and by trying to out do another company and posting higher C ratings is not going to cut it. There's a company even claiming to have their own way of rating lipos which is even more absurd. If the guys I contacted agrees to do something, we should get to the bottom of this and I hope the lipo brands out there will learn to better rate their products.
lutach is offline
Old 11-10-2009, 08:48 AM
  #416
Coldn's Avatar
thanks for attention. I sent to [email protected],
Does he have another e-mail??
Coldn is offline
Old 11-29-2009, 09:45 PM
  #417
Trader Rating: 40 (100%+)
Does anyone know if the 5200 50c clad lipo will fit in the t2 009? I'm doubting it will without the xray lipo balancing wrights but what about with them? It looks as if the 40c did. Also up until a few moments ago I had been looking at the 5200 lightning volts 24c, is it worth the extra $50 for the cmax 50c? It'll just be used for stock sedan 17.5. Thanks!
AndysD8 is offline
Old 11-30-2009, 11:37 PM
  #418
Benzaah's Avatar
Even with the lipo weights youll also need the lipo spacer kit to raise the top deck otherwise the lipo will create tweak on the chassis when flexed.
Benzaah is offline
Old 12-01-2009, 12:54 AM
  #419
drperry's Avatar
You might notice a little more punch off the line, but I don't think it would be a large amount of difference...
Unless you're geared to the moon...
drperry is offline
Old 12-23-2009, 09:03 AM
  #420
Default 50c Punch for 13.5 stock
Hi im running an SPX speedo and 13.5 stock.
Im thinking about getting an 50C+ SMC 5000 Cmax lipo. Question is whats the punch like for stock spec racing?
Also do they have the humps on the bottom?
Cheers
Toblerone is offline
