SMC Lipo info wanted.
#32
I use 4500 30c packs with 12 gauge wire with deans. They weigh 500g.
Thanks again,
Joe
Thanks again,
Joe
#34
PM sent Danny.
#35
Tech Legend
I would be very suprised if ROAR goes with a softcased lipo rule for 1/8 scale after promoting hardcased for 2S packs.
Will SMC have a certain connector on the 4S packs or recommend a type? Seems that deans are popular, and then there is that losi style connector.
I use deans but they can be a pain with larger wire than 12 gauge to solder too.
#36
Dean's connectors seem to work fine for most people. The Losi connectors are actually E-Flite connectors, E5's I think they are called. Not sure what the amperage rating is. Anderson Powerpole connectors are nice, with the heavier duty 45 amp connectors, but are a big pain to put together, especially with 10 ga wire.
#37
We will use 10 gauge wire with Deans connectors. At the moment we will release a softcase 4S/5000 as we need to study the hardcase dimensions some more as we don't want to pay for a mold only to find it the pack doesn't fit in or is not what racers want.
#38
Some company needs to come out with a super-sized version of the Deans connector, to handle the crazy amp loads of 1/8th elec. Hint, hint Danny!
#39
The more I think about the more I feel like we will not supply a connector on our pack. Unless everyone wants to use a regular Deans Ultra. I will ask Deans what there connector is rated at.
We could use the Losi EC style connector which seems to be a Bullet style connector which you can't plug backwards.
#40
I know the EC4 connector is only rated at 100 amps continuous. My guess is the EC5 is good for 125 amps continuous as a 5.5mm bullet connector is good for 150 amps, 6mm for 200 amps and 6.5mm for 250 amps. I switched from the Dean's ultra plugs to the 6.5mm bullet connectors and will never go back. Now if Losi had a EC6 connector that would be AWESOME!....LOL
10AWG wire is absolutely necessary on these 1/8th conversions. With 12AWG wire the amp draws under load can get hot enough to melt the solder.
#42
I'm pretty sure they are continuous ratings but maybe they are maximum amps. I'm not 100% sure though, just some info I got off another battery Mfg site. I'm not sure what connectors most would use but if you did supply the Dean's ultra plugs it would be a bonus for those that use them. For me, I'd just cut them off and solder on the 6.5mm bullets.
#43
I think deans will work fine. I use them and have no problems. As you said Danny that's 100amps for 3 minutes. Were not doing that. I use 350 - 400mah a minute and that's in a Truggy. Buggy are alot more efficient. Were on and off the throttle alot. Maybe full throttle 3 - 7 seconds at a time.
Plus I like the look of a factory soldier job versus mine.
Thanks again Danny,
Joe
Thanks again Danny,
Joe
#44
I'm sure once this class grows big enough that we have dozens of cars at a race you'll find that the competitive racer will likely direct solder. You'd be surprised how much extra wire and connectors weigh. If the minimum weight is 7 lbs 0.9 oz's, believe me you'll see guys doing everything possible to hit that weight....LOL
From a marketing perspective, include the Dean's Ultra Plugs.
