EVADER ST NITRO
EVADER ST NITRO
HEY GUYS, HAD A ? I PORTED THE CRANK AND SLEEVE OF MY DTX .18, WHEN IT STARTS IT WILL IDLE THEN WHEN I TRY TO ADJUST THE HIGH SPEED NEEDLE IT DIES, WHAT HAVE I DONE WRONG. IT DIES WHEN I ADJUST IT IN OR OUT. THANKS
Evader,
can you be a little more detailed in what was done to the engine. Porting... you changed exhaust timing? Transfer, boost, intake...? Did the head bubble get altered? Deck height altered (pulled a shim)? change the pipe length? Did you run this engine prior to the work you did? what does it sound like then vs now? Did you or someone else do the work?
A lot of questions, but with out a lot of detail it's tough to GUESS what's going on.
chunk
chunk
