Soaking foam tires >
Soaking foam tires
Soaking foam tires
Old 12-08-2008, 08:30 AM
Good Beer's Avatar
Default Soaking foam tires
What's a good liquid soak for soaking/making foams softer and tacky ? Regular tire tack only seems to treat the surface. Thanks.
Good Beer is offline
Old 12-08-2008, 09:03 AM
Trader Rating: 18 (100%+)
Use Paragon.
Contact Team Kamikaze in the racing forum.
Sam will hook you up
brc358 is offline
Old 12-08-2008, 09:05 AM
Derby Bros Racing's Avatar
Gojo (hand cleaner)
Rub it in and use clean rag to clean it off.
Derby Bros Racing is offline
Old 12-08-2008, 11:00 AM
Good Beer's Avatar
Appreciate the replies. I already use Paragon and GoJo but they only clean the surface of the tire. I'm looking to "deep soak" the entire tire/wheel to soften up the foam. I've seen racers pull tires out of a large pickle jar, dry them and race and they stick like gum. Just figured I'd try it myself.
Old 12-08-2008, 11:13 AM
Paragon does not clean the foam, it softens it.
I can take a set of 45 shore 1/8th scale on road tires, use the Paragon, put the tires in a baggie for three days, and they come out with shores from 37, to 40
brc358 is offline
Old 12-08-2008, 03:33 PM
kcrunchone's Avatar
ICEY HOT
but i think u will have better chance with paragon
kcrunchone is offline
Old 12-08-2008, 03:39 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
use suntan lotion (white cream type) then put them inside a zip lock bag for a few days.
Marcos.J is offline
Old 12-08-2008, 04:58 PM
Loveless's Avatar
I heard turpintine werks really well also.
Loveless is offline
Old 12-09-2008, 12:49 AM
handiman's Avatar
Trader Rating: 11 (100%+)
Default Tyres and preservation
Along the same note, what is the best method to store tyres, ie. keep them in race capable conditions whilst not in use for many months. Appreciate your advices. Thanks!
handiman is offline
Old 12-09-2008, 01:10 AM
asw7576's Avatar
Put plenty of paragon, wipe it with clean rags to remove black dust particles, re - apply paragon again, and enclose it with plastic bag, and store them in plastic box.
The best if you finish the tires in one day, so you don't have to store them.
If you have lot of new tires in stock, put them in plastic box.
asw7576 is offline
Old 12-09-2008, 02:26 AM
itchy b's Avatar
Dont forget to use 30+!!!
itchy b is offline
Old 10-19-2012, 03:14 AM
What is Paragon?
I have been using WD-40 to treat the foam wheel,but the result is not good enough, i only spray it to the surface of the tire,anyone know to use to see a better result or compared with paragon, which one has better friction?
TaoBaiBai is offline
Old 10-19-2012, 04:01 AM
R/C Tech Elite Member
EricW's Avatar
Paragon ground effects, amainhobbies has it http://www.amainhobbies.com/product_...ction-Compound
EricW is offline
Old 10-19-2012, 10:16 AM
in this case,will it last long like 45 shore and grip like 37-40 shore?
kyosho malaysia is offline
Old 10-19-2012, 10:20 AM
use yoko-yoko(analgesic liquid),you will be surprise
