MTX 5
#1906
There is no stripping gears problem, but it's frustrating to see someone new bring it up every few pages, rather than back reading to find the solution.
And the cams/parts of the steering servo saver don't sit flush out of the kit, the cup side has too much lip, keeping them from properly seating, which will create a wandering alignment, file it down and issue fixed.
will visit the track again soon and give feedback in the future.thanks to all who have given their opinions.
#1907
CSO Makes servo saver for the car
#1908
It did sound funny, I posted it then looked at it, but felt too lazy to fix it.
With the stripping second, it's more a case of you feel a bit gutted when quite frequently someone will say something like "I don't really want to buy the 5 till they fix the stripping issue", or likewise people will fear it while yet to even strip one, or strip them from lazy setup then blame the car.
It was one of those things that spread like wild fire after the cars release, and people jumped all over it, which I think hurt the sale of what is a very good car.
'Real' issues with the car got sort of almost ignored right away, like the clutch end stopper being drilled off center, fuel tank posts with the holes not drilled in them, that steering servo saver plastic slight misfit (seriously 'do not' glue your saver), and one gear alignment issue that did exist was it hard to get the pinions out far enough to 'fully' mesh the spurs, Mugen should have included some washers for behind the flywheel (I just got some of those).
#1909
Huge plus points people 'should' be aware of on the five, the car has a seriously good driveline/drivetrain, it's so light and free a slow engine can still feel quick in the chassis, also I was finishing running in my 353 last week, after a quick squirt and let off the gas, it would roll near the length of pit straight, and I'm still running urethane belts.
Also with people wondering about the new kit revisions, there is so little changed it's crazy, I was building a set of the 'new' diffs last night, if your wondering what has changed, about the only obvious one is the screw holes may be .1mm smaller and now use 2mm longer and .1mm thinner hex headed screws, anything else different is very hard to notice.
Likewise those revised upper bulk heads, don't go looking for anything super important there either, when the upper arm carbon stay butts into the alloy, they changed the alloy from a right angle, to a curve to give some more meat on the alloy part, a slight strengthening of something I'd yet to hear of anyone even breaking.
Most of the kit revisions are like that, tweaks that won't 'fix' anything as such, maybe just make things just a little stronger, but nothing at all wrong with the original kit really.
#1910
lol yeah true with the rear carbon fibre camber link brace. i purchased it thinking it had revised mounting positions, or mounting positions further out...it's just got a bloody chamfer cut on the inside bottom edge
personally i think the diff screws need to be longer and a little wider.
#1911
and thanks for ur feedback on the updated kits.seems like not much of a difference at all.i guess i will just continue running on my current one!
#1912
Its Just an Illusion
Hahaha... It just sounded funny.....
Well we saw a lot of stripped gears at the Serpent Tour so lots of user problems for the guys in Sydney...... Kickass was one of the only ones not to strip any gears.... He knows the secret but will he share?
You will have to share your secrets with the Sydney boys Dan.
The ones that don"t have this problem have merily syncrinised all 4 poles and hit a G spot, the challenge is to keep hitting this g spot.
And guess what the first time i pulled my upper bulkhead off the car it was broken and guess what again the mugen importer fails to acnowledge that this part should be replaced as a defect even when you see the new one with more beef on it,
Mugen basically sais tuff titties, just like the stripping gears just like the blowing diffs, just like the mismatching servo savers, just like the thrust ecentric holder with a wonky hole.
Oh and if anyone thinks that the driveline is free (with urethane belts) and light (with steel diffs, steel cvds, heavy spurs etc) your having yourselves on right here. Throw away these belts put the rubbers on and you will still find the side and front belts are too tight with no more adjustment.
(Capricorn drivers stop falling off your chairs in laughter right now), we don't care that your diffs are lighter, your diffs are reliable, your drive line is lighter your chassy does not hit the floor in a bow when the breaks are applied, you don't bend chassies on starter boxes, you don't blow gears, your thrust bearings spin without wobbling, you get rubber belts in the kit bla bla bla, this is all too boring for us, we Mugensuckers like a challenge, and a challenge we have got.
Other than that this is a really nice car.
#1913
well said kickass.you the man!
#1914
i dont think you guys know what it takes to set up a car.. its sad.. you will learn some time
#1915
I have merily Synchronised all 4 poles (See Below) .
Stripping gears is definately a car problem, there are a combination of issues some that are fixable and some that are not that contribute to this problem, you can eliminate the fixable issues and this minimises your chances of stripping gears. One may ask themselves why don't Xray and Capricorn drivers have to pay so much attention to alignment and mesh in order not to strip gears, i used to slap on gears on my xray bung on a motor (mesh near enough good enough) and replace spur gears a year later cause the plastic looked old. Lets be realastic here, There is an issue with gear stripping, this is not a random event.
Rear diff plastic has more meat to beef it up obviously in order to address rear diff failure with plastis gears, problem now is everybody is too scared to run plastic gears, on this car. I know all you Capricorn drivers will be chuckling at this right now as their diffs are about 15 gms lighter, these are the facts.
#1916
Robert Pietsch is participating in the Italian championship 1:10 to Milazzo (Sicily, Italy). Today we have completed qualifications. Until the third heats Pietsch was 7th in the overall standings. In the last heats entered in the first 4 finalists heade
#1917
The Car:
#1920
