MTX 5
Old 03-08-2012, 10:07 AM
  #1831
Seisick's Avatar
WE JUST HAD A INTERNATIONAL COMPETITION IN LIMA PERU
WHERE SEVERAL RACERS FROM THE REGION ATENDED
AND FROM THE MTX5 KITS SOME WITH BRACE SOME WITHOUT
NONE STRIPPED GEARS
ON SOME THE STOCK REAR DIFF BROKE OUT, IT LASTED ABOUT A GALLON - SOME TWO GALLONS FUEL WITHOUT ANY MAINTENANCE, HIGH TRACTION AND JUST RUNNING
CLOCKWISE
IF PROPER CARE IS DONE, CHANGING THE OIL EVERY RACE, AND ROTATING THE GEARS
I BET THEYLL LAST 4 OR MORE
Seisick is offline
Old 03-08-2012, 12:16 PM
  #1832
prtmotorsport's Avatar
NONE STRIPPED GEARS
CLOCKWISE
What do you mean rotating the gears?? back to forth??
sorry if i sound newbie... I am!!!
prtmotorsport is offline
Old 03-08-2012, 02:12 PM
  #1833
Seisick's Avatar
rotate left right front and rear, specially if its high traction and just one direction racing
Seisick is offline
Old 03-08-2012, 06:37 PM
  #1834
CanyonCarverR1's Avatar
Trader Rating: 13 (100%+)
Anybody seeing the T2002 kit in the states yet? I've got one on order with my LHS, getting excited.
CanyonCarverR1 is offline
Old 03-09-2012, 03:26 AM
  #1835
NONE STRIPPED GEARS
CLOCKWISE
would anyone know if capricorn diffs are this finiky? sounds a little unneccessary to save 4 grams or so of rotating mass but be given an unpredictable diff.
From all these reports of broken diff gears it is becoming apparent that at least the larger crown gears are swapped over from the plastic type to the metal type. I have full plastic gears in my rear diffs but i am thinking of changing to steel large crown gears to avoid erratic and unpredictable wear. Hopefully my next race will be at the NSW state titles, so i don't want blown gears.
TomB is offline
Old 03-09-2012, 03:42 AM
  #1836
Seisick's Avatar
Kits and uptaded parts will arrive end of this month to the distribuitor
Seisick is offline
Old 03-09-2012, 12:33 PM
  #1837
Thank you sir!!!!
TomB
NONE STRIPPED GEARS
CLOCKWISE
Today 04:37 AM
steel and plastic at the same time??? doesn;t sound a good idea....
Old 03-10-2012, 10:50 AM
  #1838
GREGORY!'s Avatar
does anyone can say to me the diameter from the mtx5 flywheel?
GREGORY! is offline
Old 03-10-2012, 06:50 PM
  #1839
Default diff
we tried km aluminium ones same as plastic after saturday we broke a diff every heat standard ones lasted 6 laps now we find out diff plastic bits that out drives go in are way to tight and this is probably the cause of all our diff troubles i though they were tight to stop leaking borrowed one from bishop and with steel already installed and bailey got to run in final with no troubles diff is still real smooth but fuel line came off at start /to lose bloody coloured stuff thanks for lend off diff bishop fellow mugen driver
greg
greg.dawn is offline
  #1840
it is 30mm
TomB is offline
Old 03-10-2012, 10:57 PM
  #1841
Bishop's Avatar
greg
No problem Greg, only problem now is even if I get a fine weather day this week, I still can't run in my 353 cause now I have no diff...
Bishop is offline
Old 03-11-2012, 07:36 AM
  #1842
GREGORY!'s Avatar
Originally Posted by TomB
it is 30mm
thank you Tom!
GREGORY! is offline
Old 03-11-2012, 09:09 AM
  #1843
greg
Is it so tight that stacking a few gaskets wouldn't fix the problem?
Old 03-11-2012, 10:27 AM
  #1844
Bishop's Avatar
No, the outdrive shafts were tight in the diff half holes, one side in particular was very tight/stiff, which would have been what was causing the diff to keep failing.
When I build my own diffs I actually put a tiny bit of grease on the outdrive pins before I slide them into the case, but I don't think that is suggested in the Mugen build manual so I'm guessing most don't do it.
In Greg's case I'm not sure what happened, or what caused it, just it really stuffed up each rebuild he kept doing within the same diff cases.
Bishop is offline
Old 03-11-2012, 04:32 PM
  #1845
Oh I see, I misread the post.
