Turbo engine in HPI Nitro RS4 3..possible??
as topic stated..
yes it it possible to put a turbo engine in a rs4 3 all you just need to do is flip the rear arms around or something like that. ive seen it done before. u just need to make room for the manifold to bend around without hitting anything like shock, turnbuckles ect. if the turbo engine is sg shaft u then need to use the wolfpack radical conversion kit. you might want to check this site out http://www.wolfpackradicals.com
you don't need to flip anything........get the HPI header and ANY rear exhaust engine(turbo or non turbo) and get it done..
Its alot easier to use use a threaded shaft engine...
