BMI Racing Discussions
#9002
T2 asphalt chasis??? when will that baby be ready???
#9004
i think the carpet out now is 2.5 and the asphalt one coming out is going to be 2.25. . .
not 100%
not 100%
#9006
Originally Posted by StephenSobottka
FRONT
Take off cs27 premount tires
Gold spring
40 wt oil
2 piston
.078 sway bar
4 degree castor
shocks are in 3rd hole from inside on tower
outside hole on arm
camber links in 2nd hole from inside w/ 4, .030 shims under the stud
Roll Center Shims- 1 or .025 front and rear on front arm
Camber -1.5
inside hole on steering knuckle w/ 4, .030 shims under stud for 0 bumpsteer
toe out 1 degree
ride height 5mm, droop 2mm over ride height
REAR
Blue Spring
40 wt oil
2 piston
shocks are in outside hole on tower
outside hole on arm
.063 swaybar(.078 if you like a nimble car)
2 degree toe in block
assoc rear hub inside hole or on losi rear hub inside hole
Camber links are in inside hole w/ 3, .030 shims
Roll Center Shims- front block .025 or 1 shim, rear block none for 1 degree antisquat
Camber -2
Ride height 5mm, droop is 3mm over ride height
Gold spring
40 wt oil
2 piston
.078 sway bar
4 degree castor
outside hole on arm
Camber -1.5
toe out 1 degree
REAR
Blue Spring
40 wt oil
2 piston
outside hole on arm
Camber -2
I'm gonna be running carpet for the first time and wanted to get my chassis setup for it. I'll be running stock with rubber tires.
Thanks in advance.
#9007
i havent been here in a while so please humor me,,
what else did bmi come out with for the tc4 after the chassis? the first one, if there ever was a second one.
#9009
i have not produced any new parts for the tc4 yet.i have been concentrating on releasing the db12 1/12th pan car,t2 and cyclone lately.i will try to get back on more hop ups soon.
the cyclone chassis prototype will be finished this week and i will be sending the prototype kit to steve weiss for testing.once i here back from him with a yah or nay i will continue on with the production.so far it is looking really cool.
#9011
ditto...
#9012
Hopefully Elvis is happy with the chassis. I know of a few people up here waiting for it.
Should be a hot seller.
Tim
#9014
Originally Posted by Bob Barry
MI2EC chassis anyone?
