BMI Racing Discussions
#3976
Guys - Ran my Xray BMI 350 chassis on Saturday on indoor asphalt. It absolutely rocks and the craftmanship is supurb! Car was very easy to drive and very predictable. Need a little more work with the setup, but it's dialed! Took 4th in the A main.
Thanks Jason for such a great product!
John
John
#3977
when putting the CA on with the que-tip, the tip on the que-tip will start to smoke and is very hazordous for you if breathed in, or that is what ive been told from my dads friend that working in a shop similer to jason's, only difference is that they make stuff for nasa.......ya just becareful when aplying the CA glue....
lazy
lazy
#3978
lazy
lazy
-Kevin
#3979
i think its the dust from the c/f and the fums from the ca that cause a chemical reaction, but im not 100% sure
#3981
Tech Legend
Trader Rating: 51 (100%+)
protc3 thanks. I know you will!!!!!!
#3982
lazy
lazy
#3983
CA !!
hey guy's .. just prep the chassis in water then instead of a Q-tip.. apply CA to the chassis edge and let it flow as you hold on to the chassis and rotating around and adding more CA as you go.. you'll get a much cleaner finish and wont have that rough edge look from the Q-tip !!!......
#3984
http://www.teamcrc.com/Html/Products/chassis-prep.html
Here's a good article on how to prep CF. It takes time but when done right it LOOKS GOOD!
#3986
Setup Request
BMI TC3 Mod with foams on smooth asphalt (medium size track). The motor is a 12x2 Orion Revolution. A suggestion on a complete car setup would be great. Also a suggestion of a starting roolut would be nice.
Thank you,
John
Thank you,
John
#3988
Re: CA !!
#3990
Re: Re: CA !!
Originally posted by Neil Rabara
That doesn't necessarily work if the edges of the plate are rounded. In fact I know it doesn't work. All I got was spill over and my thumb stuck!
I wish i had a cam.. mine chassis's come out with a black laquor finish thats pretty sweet ... I guess everyone has the way of doing it .. I just hate to use a Q-TIP to me it doesnt give that pretty finish..
