How to connect ambrc personla transponder? >
Old 11-22-2008, 09:43 AM
Default How to connect ambrc personla transponder?
Hey guy's, so i understand the ambrc personal transponder comes with a servo type plug fitted. I'm running a spektrum dx3.0 transmitter and matching receiver. Basically before i order one i want to make sure i have everything to use one, if not i'll order the pt along with what i need. Does the transponder connect to the receiver and run off my receiver battery via the auxiliary channel? thanks-Hugh
hugh_b is offline
Old 11-22-2008, 09:55 AM
Trader Rating: 36 (100%+)
I connect mine to the 3rd (or auxiliary) channel of the receiver.
rstnboy is offline
Old 11-22-2008, 09:58 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
Yes it gets its power from an open channel connector in the receiver. If you have a two channel receiver without an extra port then you just need a Y-harness.
wingracer is offline
Old 11-22-2008, 12:49 PM
cool, thanks guy's, will just plug into third channel on my receiver!
hugh_b is offline
