leaking kyosho sp2 shocks
Leaking from the small hole or tread??. If leaking from the hole pull the black rubber from inside and re -install but dont push it all the way in.
Inspect the bladders in the shock caps for tears or pinholes. The smallest hole will cause a leak and reduce the shocks performance. If they are defective replace them with new Kyosho ones.
Tech Prophet
your shock bladders are not seated properly , when you install the bladders make sure they are free and spin around in the shock cap . there is a groove that they sit in , i suggest using some green slime when putting your shocks together and sanding the top of the shock body so there isn't a sharp edge to rip the bladders
