Slash Bash Trophy Race at Battle Front January 23
For all of you Slash fans out there, Friday January 23, Battle Front Gaming and R/C will hold its first Slash Bash Trophy race. We will have a spec class and with enough interest a mod class if 3 or more mods sign up. More info will follow about start times and such, we just wanted to get the idea out so you Slash racers can make plans to join us. Rules for the classes are as follows:
1. Box Stock means you may change only the following: esc, receiver/radio, shock oil, caster/camber. You must run either the 18 or 23 pinion that comes with the truck and the 86 tooth spur. You must run the Titan motor. Period, that's it!
2. Modified means you can run any 13.5 or higher brushless or 19t or higher brushed motor or a stock Titan if you want. You can change anything and everything else: tires (must be made specifically for the Slash), steering servo, spur, pinion, put aluminum shocks on it, put any aftermarket part you want on it, go nuts!
3. You may run any aftermarket body made specifically for the Slash in either class. You may run any 6 cell NiMh or 2s lipo in either class.
4. Stock compete with stock, modified compete with modified. If there are enough of each they will run in separate heats. If not, they run GTP style all at the same time. You might finish 3rd overall, but win the stock class. Heck, you might finish first with your box stock Slash and beat all the mods.
Here is some more info on the event.
8:00 pm start time
$20.00 entry first class
$10.00 second class
Pizza and pop will be provided
3 heats and the main
Trophies for the first three paces in each main
There has been a change to the mod class. You can run what ever motor you brung. No restrictions on motors in mod. The other rules remain the same.
Saturday and Sundays regular race programs will be running.
Lenman
8:00 pm start time
$10.00 second class
Lenman
All details and the entry form for this event are now available at:
http://www.fatalimpactracing.com/
