Awesomatix EP Touring Car (A700 Shaft Drive)
#6227
6 new setups just posted online. http://www.awesomatixusa.com/p/setup-sheets.html
Josh's Mile High winning setup was almost the same to what he ran at the Pre Worlds. The only difference was at Pre Worlds his rear swaybar was 1.0mm.
question ,about Josh mod car..the rear hub is moved to longer wheel base or short?
#6230
Hi , last weekend i was testing on a low grip asphalt track.
It was first time this year that we hit this track. So grip levle was really low.
I used some different setups for this conditions.
With new AM06M wheelhubs the grip were okay in this conditions.
If you are interessted i attached the Setup here in the end of the post.
Best Regards Max
Best Regards Max
#6232
Best Regards Max
Best Regards Max
#6233
Someone interested in a brand new C01EX (EX/EXL chassis) never used, and a brand new spool (AT03 + outdrives and bearings), never used, for only 155$ including worlwide shipping?
PM me if interested
Cheers
G-rem
PM me if interested
Cheers
G-rem
#6234
#6235
Ok. For outdoors and im asuming low traction since its seatfle so it notwarm yet and its the first race of the asphalt season. Spool or diff in front. Btw my car is the a700. Setup is posted under jaybee on the awesomatix site. Still very new to the car but love it.
#6236
#6238
For asphalt it would be better to change the bottom chassis to EX or L chassis ,
the stock A700 is a little too stiff...
#6239
Wobbly diff Outdrive
Has anyone experienced a wobbly outdrive on the gear diff (not the GD2).
Here's a video of the wobble (visible when the motor is going at low revs)
Any advice on how to eliminate the wobble would be most appreciated. TIA
+ YouTube Video | |
#6240
You should check the inner ball bearings and the O-ring.
If you have any doubt on them, change them.
