Awesomatix EP Touring Car (A700 Shaft Drive)
#5028
R/C Tech Elite Member
the only other thing i can think of is that your servo is too far forward and the links are hitting when your near full lock. this mostly happens right in front of the servo.
i've added 1.75mm to my servo (sanwa sgr-bls) between the am24 to allow me to move the rack back w/o any interference.
another hint is to make sure your rack is centered. i use a caliper to measure the difference from the bearings to bulkhead. it is about 10mm on each side.
these are the only other ideas i have...
#5031
Should have had Arvin Nano work on it.
#5033
Here's another idea ...New A700 upgrade: 4mm carbon fiber shaft(3.5grams) from E. Wippler... The lightest shaft ever.....
#5034
What's are the differences between GD2 diff and current diff. ?
#5036
^Ditto. The GD (1st gen) if installed/build correctly (my way: combined plastic and metal satellite gears) is smooth as silk & indestructible, hence making it superior with the release of GD ver 2 bundled with the pinned outdrives. This update is sick. Another superb job from Oleg and co.
#5038
I don't have a totally un-messy way of filling the diff yet. These parts work best so far--
Mcmaster 5233K113 Clear—Metric PVC Tube
Mcmaster 7510A653 0.34 oz. (10 cc) Regular Syringes with Luer Lock Tip
Getting the same model syringe but w/ a bigger volume would work better.
Making your PVC tube as small as possible also works.
I don't have a proper on/off valve so I can build pressure in the system first. Basically the setup was-
0. removing set screws from diff ends
1. associated diff oil bottle w/ cap off
2. short tube to one diff end
3. short tube from other diff end to syringe
4. action the syringe until fluid starts flow
5. wait for air to stop flowing.
6. take tubes off diff and install set screws.
#5039
That sounds brilliant. So you've got a bottle of fluid at the bottom, diff in the middle and a syringe on top to suck the air out from the top, pulling the fluid in from the bottom so there's no air left/perfect bleed? Genius, so easy!
