Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 11-21-2013, 09:05 PM
  #4816
Oleg, I tried to Pm you but no luck... Anyway, I am trying to send you some funds $185 for my order(10001386)... Let me know where to send it via western union ASAP... thanks....
bertrandsv87 is online now
Old 11-21-2013, 09:44 PM
  #4817
Got the info... Thanks Oleg...
Old 11-22-2013, 12:50 AM
  #4818
hana166's Avatar
Originally Posted by Oleg Babich
Please check the length of your cross pin.
It should be short enough ( ~10,4 x 2 = ~20,8mm) for free movement in the slots after screwing of the diff's cases. This is very important!
All our test diffs are smooth without any sanding of the original gears ( ~ 4.35mm thickness). Our big washers are 0,3mm and small washers are 0,2mm in thickness.
Thanks Oleg for your advice I did not cut the cross enough the first time I assembled the diff and it was very tight. I cut it down further and it was almost perfect. Free but one notch. After some time I found there was a high point in the mesh. The xray gears are not perfectly concentric. The tolerance is actually quite disappointing.
hana166 is offline
Old 11-22-2013, 09:45 AM
  #4819
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Fyi - caster doodles are made and shipping to AwesomatixUSA today. Should be available in a few days..
hanulec is offline
Old 11-24-2013, 04:21 AM
  #4820
Adam B's Avatar
I noticed an issue yesterday. The nut for the center bearing on the steering rack is rubbing the driveshaft. Only way I see to repair this is to shim between the steering rack and where it mounts. Am I missing something?
Adam B is offline
Old 11-24-2013, 05:46 AM
  #4821
hana166's Avatar
Default Shock brace
Was wondering about removing or cutting the brace between the shocks at the rear particularly - a bit like the idea of using split blocks.
Anyone tried this? Obviously the suspension works quite differently on this car so I don't expect the same results. Just curious, thought it might be an idea to try
hana166 is offline
Old 11-24-2013, 07:50 AM
  #4822
hanulec's Avatar
Hi Adam- the wear you see on the at04 is nothing to be concerned about -- unless the shaft has a groove that you can measure w/ a caliper. i've been running the same shaft/same car for 11+ months now -- no issues w/ shaft failure (i was going to say no issues w/ failure --- but people have seen my driving before).
hanulec is offline
Old 11-24-2013, 08:13 AM
  #4823
erchn's Avatar
AM08-1? What would hold the springs onto the shock properly?
erchn is offline
Old 11-24-2013, 08:57 AM
  #4824
hana166's Avatar
If you cut it in the middle or something like, the springs will stay on, the groove in the baseplate should keep the shock inline?
hana166 is offline
Old 11-24-2013, 09:11 AM
  #4825
erchn's Avatar
Way back when, if that middle screw came loose or if I forgot to install it (duh) I had problems with the springs staying on. That was without the possibility of the piece pivoting on those outer screws, since it would now be cut in half.
erchn is offline
Old 11-24-2013, 10:42 AM
  #4826
Quantra's Avatar
Are you sure it's the nut which is rubbing? If you have a mark in that area on the drive shaft it could be the ST21 servo track rod that is rubbing at full lock. It's worth a look as it's quite tight and tricky getting it right so it doesn't hit the top deck or main shaft.
Quantra is offline
Old 11-24-2013, 11:32 AM
  #4827
hana166's Avatar
You know its funny, whenever someone tells me something isn't a good idea that's when I know I absolutely must try it.. I'll report back later !
hana166 is offline
Old 11-24-2013, 12:06 PM
  #4828
erchn's Avatar
Lol, good luck. :-)
erchn is offline
Old 11-24-2013, 07:00 PM
  #4829
Adam B's Avatar
I am positive it was the nut. I forgot I had ordered the floating servo mount, so when I put it on I checked the nut. It had just backed off.
Adam B is offline
Old 11-24-2013, 10:22 PM
  #4830
hanulec's Avatar
if folks haven't check out Karl H. setup from the Halloween Classic -- please do so. i took some aspects of this setup (swaybar and shock/spring) and applied it to my base setup this weekend. it was a bit quicker yet still easy to drive. i hope to apply the entire setup for this weekend...
hanulec is offline
