Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 09-30-2013, 06:35 PM
  #4411
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Originally Posted by grippgoat
Have you tried using rear bump steer to have less scrub when going straight, but plant the rear more as the car sets into the corner, particularly when the rear is compressed on power?
Just curious, since that's a tuning option that's pretty unique to the awesomatix.
-Mike
Personally I havent played with it yet, ive always set it to be 0 bump. Im at the point now where maybe ill play with it. I dont think you would want to get too crazy with how much change you have though, because then you would have to make sure you drive the car exactly the same every corner to get the same feeling from the toe every lap. I would suggest if someone isnt 100% confident in how everything else works setup wise you leave the rear bump toe static, there is plenty else to learn & change to get a dialed car
geeunit1014 is offline
Old 09-30-2013, 06:43 PM
  #4412
Anybody used progressive Rear Caster yet ??? Moving the rear wheel towards the rear when the suspension compresses will act like rear steering....
bertrandsv87 is offline
Old 09-30-2013, 08:41 PM
  #4413
JayBee's Avatar
Trader Rating: 31 (100%+)
Someone correct me if I'm wrong but are the dampers put together by special equipment, so much as to not allow reassembly by us heathen? I for one would like to check things out...
JayBee is offline
Old 09-30-2013, 08:58 PM
  #4414
I have taken apart an old shock to look inside to see how it works, but could not get back together right. I remember hearing or reading that the shocks are assembled by hand and built in a specific order.
Patrick
XCELL is offline
Old 09-30-2013, 09:12 PM
  #4415
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
let say ,,you could take it apart and put back together..what hydraulic oil will you put in ?
OVA is offline
Old 09-30-2013, 09:16 PM
  #4416
JayBee's Avatar
Good question...
JayBee is offline
Old 09-30-2013, 11:23 PM
  #4417
alainchan's Avatar
new trial chassis
http://shop.awesomatix.com/index.php?categoryID=571
alainchan is offline
Old 10-01-2013, 12:45 AM
  #4418
I really do not recommend to open the shocks. With a bit of luck you will get it back together but in 99% there will be air inside after disassambling. The best is to send them back for maintance to Taiwan factory but I honestly run still some of my first shocks... And they have many flights, races and so on behind them :-P
I am really looking forward to Vegas. First time on US style carpet track! It will be interesting. I will use all the new parts so who want to check them, just came by :-)
Really looking forward to meet many new people!
See you
Freddy
FreddySudhoff is offline
Old 10-01-2013, 03:47 AM
  #4419
part-time racer's Avatar
Originally Posted by hanulec
when the car goes slower, the more rear toe you normally need.
3.5 degrees was the 'hotness' to lock in the rear from otherwise being loose. if my car feels to tight at IIC, changing the rear toe will be my first change for sure...
This is interesting because it is the reverse of what is normally done here in the UK.
I will try going back to 3* from the current 2.5* but also trial the rear bump steer idea as explained by grippgoat .
part-time racer is offline
Old 10-01-2013, 04:57 AM
  #4420
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Freddy - it should be great to meet you. I know you'll be ready and willing to turn some wrenches to get your car good. On the flight over try to pick Ronald's brain... That is unless he isn't attempting to steer you in the wrong direction. People only usually start doing that when they realize your a threat
Richard - I honestly think that rear toe and droop changes can usually take an average handling car and make it great. Hopefully you'll find similar things...
hanulec is offline
Old 10-01-2013, 07:39 AM
  #4421
Smile
Good luck Freddy in the mod class , and have fun !!!!
Old 10-02-2013, 12:31 AM
  #4422
Velocitygt's Avatar
Hi Guys,
Awesomatix now has an official Facebook Page!
Oleg will be keeping it up to date with all the latest Awesomatix news.
Please "Like" the page to stay informed!
http://www.facebook.com/awesomatixRC
Velocitygt is offline
Old 10-02-2013, 04:14 PM
  #4423
JayBee's Avatar
^^^DONE!!^^^
JayBee is offline
Old 10-02-2013, 05:51 PM
  #4424
hanulec's Avatar
four words - Caster Doodles are here!
See them in person at IIC. First public viewing will be Sunday, Oct 6th at the Awesomatix USA Pre-IIC Party (otherwise known as Tequila Sunday).
hanulec is offline
Old 10-02-2013, 06:47 PM
  #4425
Trader Rating: 44 (100%+)
Save me some for hangover Monday!
Monti
Monti is offline
