Awesomatix EP Touring Car (A700 Shaft Drive)
#4261
#4263
#4264
#4266
It might as well been a single color because it wasn't memorable Yes, winning Reedy will make up for not making the high school football team or going to prom. Ultra-large bowling ball trophy next to the family portrait is a wonderful centerpiece.
The Xray thread too quiet for you today or something. Go watch football and polish that Reedy centerpiece!
#4267
But, don't be sad lil panda, we still love you.
#4268
Do You use ball diff in rear in any circumstances? When? have You tried it? I can't find any setup with it...
In our track (very slipperi carpet with Sweeps, tight cornes, 1/12 style track) the car turns better and is faster without stabilizers... I have tried Viljamis setup, low roll center setup and Henriettas setup: short links, long links... With stabilizers the car feel ok, but little bit "floaty". Do You use stabilizer in any circumstanses and have You noticed same?
#4271
Hello all,
My car started to do wierd things in the middle of the curve, and I have found that one of the dampers is working softer than the other three, and is leaking a bit of oil from the seal.
The outside looks OK.
Is there any kind of repair to do instead of buying a new one?
Thanks in advance, regards!
#4272
Hello all,
As for the softer feel, did it feel softer in just one direction? I would make sure the screw in the back of the dampener is tight, as this controls whether the dampener as a asymmetrical feel up or down or the same both directions.
#4274
Not sure on the leaking oil, if it's just little and the car is new this is normal and it will stop.
The car is now around 10 months old, the joint looks always wet and rotates with the damper .
Regards!
#4275
http://www.awesomatixusa.com/p/setup-sheets.html
