Awesomatix EP Touring Car (A700 Shaft Drive)
#4141
now when i set the right height in the front screw i 10 turns and when i so check the height is it 6 mm in the right side and in the left side is it 4,6 mm why that ?
#4142
1) Theres something bent
2) The car isnt balanced well
Cheers
Cheers
#4143
i have checked there are nothing bent and how can i balance the car right
#4145
will it be a good thing to use a tweak board ?
#4146
If you have crashed check the springs to see if one is bent
If they are not straight then bend them straight or replace. Set droop exactly
Carefully turn ride height screw until the slack just disappears
Then you know there is zero preload. This will get the car approximately correct
Set ride height by turning equal amounts both sides
Use a tweak station or whatever to get the preloads correct.
I use two fine pins to get left right balance perfect, then 4 scales (which I set up carefully first)
#4147
WOW price tag almost gave me a heart attack!!! Anyone have a coupon code? I want this car BADLY!!!
#4148
Kit: 500
ECS: 100
Shock oil: 50
springs: 80
Total: $730
Once you add this stuff up you will see that a lot of people end up spending just as much or even more. ECS drive shaft are not needed but a lot of people end up buying them because they run 17.5 or 13.5. hope my break down takes away some of that sticker shock.
Jerry
#4149
Any of you guys have any issues with the gear diff gears stripping out? Ran my new car today and after about 10 packs the car started spinning out in the corners. Checked the rear gear diff and it seemed that the gears were notched causing the diff action to not be smooth. Big props to my main man Karl H for hooking me up with some of his extras. Other than that issue the car was money.....only about 3 tenths off of our local fast guys For me that's not to bad
#4150
http://www.petitrc.com/reglages/awes...fModification/
#4152
What about the price got you.. let's see.. an L car is I believe $700.. so let's do some math.. Xray is a popular car so i'll use that as the base.
Kit: 500
ECS: 100
Shock oil: 50
springs: 80
Total: $730
Jerry
Kit: 500
ECS: 100
Shock oil: 50
springs: 80
Total: $730
Jerry
Still though it's one hell of a good looking car!!!
#4153
The car is worth every penny. No more lugging around 10 bottles of shock oils leaking all over the place, no more lost/missplaced springs. No more snapped chubs or knuckles. More positives to this car than negatives.
#4154
Oh I don't doubt that at all. The quality and finish looks amazing, just gotta figure out a way to hide the purchase from my boss (wife). 500-600 not a problem, close to 1k her eyes they're WIDE open!!!
#4155
*I used to hide all the expenses too from my wife, hehe.
As for the gear differential, I purchased the optional G05ST and G06ST and they settled well without shimming, smooth as silk. Now, I want to try if the combination of plastic and steel will be at par or better. I'll post the update.
Cheers and good day to all.
