Awesomatix EP Touring Car (A700 Shaft Drive)
#2746
Thanks a lot Oleg...planning to buy a EX main chassis
#2748
I have brand new parts for sale for the a700 check my for sale thread, pm is the key thanks
#2749
Are G05 and G06 plastic/carbon gears diff the same as Spec-R SPR010-G2?
Thanks,
G-rem
Thanks,
G-rem
#2750
Thanks a lot for your rapidity Oleg
You spoke about metal gears; is that useful for 10.5 blinky class? No problem with that knd of gears? Any advices in comparaison to the plastic one?
Regards,
G-rem
Regards,
G-rem
#2752
I was going to ask the exact same thing. I experienced lower temps in the past in transverse orientation. The air underneath the car cools the motor, and it does seem to be very significant. I ran an inline setting, cut a hole in the baseplate on a old chassis, deepening the original slot all the way through, and used a fan on top, which blew air around the motor and out the bottom of the chassis and had the lowest temps of any previous set up.
#2753
Chassis cut outs
Hi hana166,did you find cutting the chassis under the motor caused different flex points on the chassis as the other side is solid plate,or did you also cut out the other side to match up.
#2754
Just the one side. I didn't find the handling any different. It was just one of many experiments, and did produce really low temps. Regarding flex these days I use a completely solid prototype C01L and uncut top deck, pretty much the opposite of where I was six months ago. Top mounted fan still does a good job without the cut out.
#2755
hello, im from spain and im interested in the new car, wich one do you think is better on asphalt track and using both stock and mod?
#2756
The L or the new EXL ;-)
#2757
Any video comparisons of the models ???
#2759
Never ....ahahah.... Just want to keep up with the shaft Car improvements to apply a few to my tc4.1... I'm always hungry for knowledge(free that is)....lol... I see alot of improvements to the A700 already......
#2760
If anything, I would add the Awesomatix to my stable, not to replace my tc4's though, and would only run the transverse motor setup since I already have the longitudinal setup.... Only if I had the money though($1000)....lol.....
