Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 02-16-2012, 09:29 AM
  #1621
erchn's Avatar
Originally Posted by wwddww34
Does anybody have a spare A700 chassis that they can sell?
They do sell them separate on the Awesomatix website, and seem to be in stock.
http://shop.awesomatix.com/index.php?productID=738
Ethan
erchn is offline
Old 02-16-2012, 10:35 AM
  #1622
Skiddins's Avatar
Originally Posted by Mb3195
If you find one in stock in the uk, let me know where from.
Originally Posted by hana166
Do you have a product code for this (east coast) body plz?
Also anyone have any experience with Blitz bodies? They were brilliant on my 1/8 onroad, very good quality, just wondering how the 190mm bodies are.
I used the first one mentioned above, but it doesn't seem to be on Schumachers website anymore, mine dates back to when I was still running an Mi3 but sadly I destoyed it on Sunday at Rug Racers .
As a replacement I now have one of these (lightweight version), will see what it's like at the weekend;
http://www.eastcoastbt.com:8081/en/p...tails.php?p=33
Skiddins is offline
Old 02-17-2012, 09:10 AM
  #1623
Trader Rating: 38 (95%+)
Hi I have a brand new a700 for sale, if anyone is interested let me know thanks
zaraz is offline
Old 02-17-2012, 10:36 AM
  #1624
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
It is all depending
How much?
PM me if that work for you..
OVA is offline
Old 02-17-2012, 05:05 PM
  #1625
Airwave's Avatar
My A700 is fully build and ready for action...
By the way, three questions:
- On my 4 dampers, only one have a small silver shim just under its "symetric screw", is that normal? Should I let this shim or remove it?
- How could I measure droop (= downstop) on this car (the setup says 26mm...)???
- Is it possible to buy only the four dampers?
Thank you very much...
Airwave is offline
Old 02-17-2012, 05:11 PM
  #1626
jake95's Avatar
Trader Rating: 27 (100%+)
i tried the car for the 1st time last night was pretty happy with it.I had a couple of issues with the gear diff (chewing gears) which has been all sorted now.I ran kit setup which had good turn in but was pushing mid corner and exit.i softened the front damper and that helped allot has a good amount of steering i will try longer links next which im sure will improve the stability and steering.but overall happy with the car didnt have that much track time due to the gear diff problem.i am impressed in how good it reacts to changes.
jake95 is offline
Old 02-18-2012, 12:52 AM
  #1627
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 101 (100%+)
Is there a place in the US we can get these cars? How much are they?
BSchorr is offline
Old 02-18-2012, 03:59 AM
  #1628
Just measure the droop from the bottom of the wishbone as any other car.
Yes you can buy the dampers separately.
Mb3195 is offline
Old 02-18-2012, 04:36 AM
  #1629
You have possibility to shorten SB25x8 screws by 0.2-0.3mm with broach file and remove small silver shims after that.
Oleg Babich is offline
Old 02-18-2012, 03:02 PM
  #1630
Trader Rating: 12 (100%+)
Lous Speedway is a dealer (in Canada) and started bring them in. He might have one in stock for sale, but not sure how it costs.
Cheers.
Turillo is offline
Old 02-19-2012, 10:56 AM
  #1631
hello;
i struggled today on a bumpy technical carpet track,
the back of the car was bouncing around, no way to find a good setup..
soft dampening as the one on freddy setup..nope..try Tom Maquel dampening nope..any help..thanks
just wanna know how u people choose your dampening cause i can see a lot of possibilities...when to go less or more A or B distance, confused with that..
thanks for ur help..
method699 is offline
Old 02-19-2012, 11:22 AM
  #1632
Magnet Top's Avatar
Magnet Top is offline
Old 02-20-2012, 02:49 AM
  #1633
Damon's Avatar
Originally Posted by method699
hello;
I have same problems in ETS Round 2 (Italy), with the advices of Laptev I found a good setup with antiroll bars, very soft dampening, front and rear kick-up, more droop
look the attachment
File Type: pdf
Damon is offline
Old 02-20-2012, 05:20 AM
  #1634
TryHard's Avatar
Just a quick update from the TITC practise.
Myself and Tom have been working away pretty hard on modified settings, and both are now running the car the same... and feel very happy with it, good corner speed, and good reaction... no hint of traction roll yet either. I've got down to 16.1's, with Tom cracking 15.9's, with the fastest mod boys doing consistent 15.6's, so to be that close to the pace is very pleasing.
Tracks really really busy, so it makes it difficult to get a clean run in, which is certainly making it tricky for me to get in a groove, as I'm sure there are a few more tenths to come from improving my lines and so on. Car itself has proved to be very tough, given some of the unfortunate incidents leading to meeting's with the concrete wall.
Plan for tomorrow is to play with the rear link heights a little, then work on refining the damper and spring settings. Anyway, settings as of now attached.
Regards
Ed
File Type: pdf
TryHard is offline
Old 02-20-2012, 08:22 AM
  #1635
Hi, I brand new a700 for sale first 800 usd shipped to canada and lower 48 states,get its only today , lol, sale sale sale, pm me, more info. in the for sale section thanks
zaraz is offline
